Author Topic: Tornado Configuration for MAME?  (Read 1342 times)
matt_esch
  • Last login:December 30, 2009, 09:49:38 pm
« on: November 01, 2009, 10:17:15 pm »
Hi Folks - First time poster, but long time lurker ;-)
So, I've got my cab up and running - this forum has been a great resource/tool.  However, I have not been able to find much guidance on this forum (or others), on how to configure a Tornado spinner in MAME.
The spinner works well in Maximus Arcade UI, and Stella.  However, I can't get it to work in MAME...  Here has been my approach so far, that has not led to success:
- Within MAME, I enter the MAME Configuration utility (TAB).
- I select either "Input (general)", and/or "Player 1 Controls".
- I attempt to update the Dial and/or Paddle Analog assignments by hitting "Return" key.  Right now, default assingments are "Mouse X".
- When I go to assign the Tornado spinner activity to the controls, nothing happens.
Any recommendations?  I've seen some suggestions to modify the mame.ini file.  however, I don't have one of these as I am not using the MAME32 UI.
Any help would be appreciated.  Eager to play some Championship Sprint!
Thank you,
Matt
mytymaus007
Re: Tornado Configuration for MAME?
« Reply #1 on: November 01, 2009, 10:52:25 pm »
do you have multiple mouse setting on in the default settings in mame
matt_esch
« Reply #2 on: November 01, 2009, 11:29:58 pm »
Hi - Thx for the quick response.
I see that multiple mouse is an option on line #809 of: http://mamedev.org/source/docs/config.txt.html.  And, that the default is "Off".  That being said, that's probably my problem.  But, I don't see where to update that setting.
mytymaus007
« Reply #3 on: November 01, 2009, 11:36:25 pm »
open mame Options tab/default game options/controllers/multiple mice should work if your using mame32
matt_esch
« Reply #4 on: November 01, 2009, 11:49:46 pm »
hmmmm...
What if I am not using MAME32?  Correct me if I'm wrong, but aren't Maximus Arcade (MA) and MAME32 mutually exclusive?
Or, should I be using MAME32 in conjunction with MA?
Ummon
  • Trade Count: (+13)
« Reply #5 on: November 02, 2009, 12:27:57 am »
Look up MameUI, look at the 'default game options' and see what it enables, controls-wise. Also read the help file with it to understand what's happening at a file level.
Yo. Chocolate.
Stephen Hawking
matt_esch
« Reply #6 on: November 02, 2009, 11:08:16 pm »
Thanks, guys!  Got it fixed up.  It is working great!
I followed the directions on how to create the mame.ini file, then modified the mame.ini file to enable mouse control for the spinner.  Boom!  all set.
I appreciate the guidance.  Much appreciated.
matt
