Author Topic: Broken Pot on WG7131  (Read 1507 times)
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
« on: November 01, 2009, 07:03:58 pm »
I broke the pot for the contrast control on the seperat board, where can I find a replacement for this? Its a 10k
Best of the Best of the Best. Sir!
SirPeale
  • Green Mountain Man
Re: Broken Pot on WG7131
« Reply #1 on: November 01, 2009, 07:07:15 pm »
I'm sure Mouser would have one.  Let me check.
edit: This?
« Last Edit: November 01, 2009, 07:13:03 pm by SirPeale »
speedklz
« Reply #2 on: November 01, 2009, 07:30:31 pm »
Uf it were on the main board, but these are on the seperate board and they lay flat.
speedklz
« Reply #3 on: November 01, 2009, 07:36:21 pm »
this is it.
SirPeale
« Reply #4 on: November 01, 2009, 07:55:18 pm »
Oops, well, here you go.
speedklz
« Reply #5 on: November 01, 2009, 09:26:08 pm »
You tha man.. I looked through the site for 30 min and could not locate it even when I tried the search.. Thanks.
SirPeale
« Reply #6 on: November 02, 2009, 06:53:17 am »
I've found the easiest way to find things on Mouser is to start right at the beginning and break the part down using the multiple choices.  For example, I started out with "Passive Components" then moved to "Potentiometers and Rheostats" and from there to "Trimpots".  After that I just looked at pictures until I found the right one.
That last part can work against you though, always make sure to check datasheets.  Sometimes they just put up a picture of a part in that class, but it could have a different style of mounting, etc etc.
