Author Topic: Medium Resolution Monitor Help  (Read 1547 times)
OverRide
  • Last login:January 11, 2026, 04:25:09 pm
« on: October 29, 2009, 02:38:15 pm »
I'm starting a new MAME project soon. I have a line on a couple different Medium resolution monitors but I not sure if this is the way to go.
Do you use an ArcadeVGA with medium resolution monitors (from what I can tell, no). And if not, what do you use?
How do the low res games look on a medium res?
Is this a good solution, or would a TV be better?
Thanks.
« Last Edit: October 29, 2009, 03:10:53 pm by OverRide »
OverRide
Re: Medium Resolution Monitor Help
« Reply #1 on: October 31, 2009, 01:18:15 pm »
Should I maybe post these somewhere else? Just looking for a Yes or No/Pro or Cons on Medium resolution monitors.
Thanks for any help.
2600
« Reply #2 on: October 31, 2009, 01:52:19 pm »
Unless you are trying to play just the Medium Resolution games a Medium Resolution monitor is a poor choice for a MAME cabinet.  >90% of games are CGA
That being said.  Some Medium Resolution monitors have a jumper to switch to CGA.
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #3 on: October 31, 2009, 02:23:37 pm »
I believe your decision should be based, in part,  on what you plan to have your MAME rig do.  I initially had a 32" TV planned as my monitor.  It worked great for the MAME arcade games, but when I wanted to have the nice crisp look of pinball tables at higher resultions, I realized the TV was the Achilles heel.  I decided to go with a 19" CRT monitor, although I wish I had a larger monitor.  Personally I prefer the ability to have the higher resolutions as it gives more flexability for your MAME cab.
Galaga... Was there any other game?
