Author Topic: Monitor adjustments  (Read 1111 times)
stephanh
  • Last login:January 16, 2012, 10:22:36 am
Monitor adjustments
« on: October 29, 2009, 08:55:24 am »
Hi all,
For those of you who have WG monitors, what do you do with that circuit board that has the adjustment buttons? Do you leave it inside the cab? Do you mount it on the outside? If so, is there a front fascia/cover one can get for that?
Steph
grantspain
Re: Monitor adjustments
« Reply #1 on: October 29, 2009, 08:10:40 pm »
normally they are mounted in the coin door area or under the cp
