Author Topic: Error compiling: defining input in neogeo.c  (Read 1844 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
« on: October 25, 2009, 03:06:03 am »
I am trying to change the enter bios input (only in input this game) for all Neogeo games editing the source code. I'm using neogeo.c, where I've found this:
   PORT_BIT( 0x0080, IP_ACTIVE_LOW, IPT_OTHER ) PORT_NAME("Enter BIOS") PORT_CODE(KEYCODE_F2)   \
I can change keycode_f2 to keycode_b and it compiles and works. I can change it to JOYCODE_BUTTON8 and it compiles and works. However it doesn't compile if I write JOYCODE_1_BUTTON8 and the same with JOYCODE_1_BUTTON8 JOYCODE_1_BUTTON9 or what I first tried: KEYCODE_F2 OR JOYCODE_1_BUTTON8 JOYCODE_1_BUTTON9, which is what I have in a neogeo cfg file after editing the enter bios input (button combination to enter bios)
Any idea what's going wrong?
SirPeale
  • Green Mountain Man
Re: Error compiling: defining input in neogeo.c
« Reply #1 on: October 25, 2009, 07:35:09 am »
That's an awful lot of work, why don't you just change the inputs on the input menu?
Stormrider
« Reply #2 on: October 25, 2009, 01:30:37 pm »
Because I'm masochist
« Last Edit: October 25, 2009, 02:37:42 pm by Stormrider »
Stormrider
« Reply #3 on: October 26, 2009, 06:48:04 am »
Nah, it's just that creating a neogeo.cfg with the custom input configuration simple doesn't work.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: October 26, 2009, 05:56:05 pm »
Mame can do ORs with two PORT_CODE()s:
PORT_BIT( 0x0080, IP_ACTIVE_LOW, IPT_OTHER ) PORT_NAME("Enter BIOS") PORT_CODE(KEYCODE_F2) PORT_CODE(KEYCODE_B)   \
results in "F2 or B".
But it's not setup for hardcoding ANDs.  If you want to do this, I think you'd need to #define a PORT_CODE_AND, setup the tokens and write the new input_seq_append_and() function.  (Copying from the INPUT_TOKEN_CODE token and input_seq_append_or() function)
Robin
Knowledge is Power
Stormrider
« Reply #5 on: October 26, 2009, 06:59:49 pm »
I've finally got to simplify an autohotkey script and make it work. I've added it to code of the script I'm using. This is the code:
#IfWinActive ahk_class MAME
~1Joy9::
if getkeystate("Joy3")
Send, {F2 down}
Send, {F2 up}
return
Apart from buttons for pause, show fps, coin and start, I use button combinations for using MAME's UI. The different action buttons + start button (joy9) perform functions: throtle, menu, overclock, service menu, reset, quit. Now, thanx to the script, when I press joy3 + the start button, I enter the service menu or bios (in case I am running a Neogeo game).
« Last Edit: October 26, 2009, 07:14:37 pm by Stormrider »
