Author Topic: Check out my cool rotating monitor plans  (Read 2728 times)
erics
  • Last login:October 30, 2009, 10:47:50 pm
« on: October 19, 2009, 10:37:46 pm »
Hi All.  Long time reader, first time poster.
I just finished designing and building my first cabinet and came up with a rotating monitor design that was pretty easy to build out of easily available parts and so far has worked awesomely (knock on wood).  Since I learned so much from this board, I wanted to share my plans.  I posted them on my blog at http://ericmanarcade.blogspot.com.  Check them out, especially if you are thinking about doing a rotating monitor.  If you're interested in more details, leave me a comment and I can post more details and photos.
Enjoy.
phatmeat
  • Last login:May 25, 2013, 12:08:55 am
Re: Check out my cool rotating monitor plans
« Reply #1 on: October 19, 2009, 10:45:38 pm »
 Good idea ..  Interested to see more..
erics
« Reply #2 on: October 27, 2009, 10:20:11 pm »
I added a lot more details including lots of photos on http://ericmanarcade.blogspot.com.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: October 27, 2009, 11:16:34 pm »
Simple AND effective.  :cheers:
That doesn't look like it would be too terribly hard to make it automated either.  ;)
Ummon
  • Trade Count: (+13)
« Reply #4 on: October 28, 2009, 04:32:32 pm »
Yeah, way cool idea for the monitor rotation. How soft are the skate wheels?
I dunno about motorizing that, though.....where would it connect?
Neat CP, though I wouldn'tve dedicated one of the sides to a single stick and buttons, but rather a yoke or something. Even standing up though (which I don't prefer, anyway), I would sacrifice some comfort by using the dual stick side for single-player games, as I have always done on my panel - P1 stick, P2 buttons.
Yo. Chocolate.
Stephen Hawking
Kevin Mullins
    • Me on Myspace
« Reply #5 on: October 28, 2009, 06:48:10 pm »
The lower skate wheels hold most of the pressure from the weight, so my first thought was to drive one of those wheels. A rubber wheel of sorts on the end of  a motor shaft pressed up against one of those wheels should do it. Not going to be turning it at high rates of speed or anything.
Just a theory anyways.
erics
« Reply #6 on: October 29, 2009, 09:07:45 pm »
The skate wheels are pretty hard rubber.  I don't think you could dent or bend them.
I thought about that, but my dual sticks are 8-way and they're off center.  The main reason though was just that I liked the classic look of a single, centered ball-top joystick.  To each their own I guess.
I tried and you can indeed rotate the monitor by spinning one of the lower skate wheels.  It seemed like it took a bit of torque though.
What kind of motor would you use?  Would the magnetic field of the motor mess up the monitor colors?  I was thinking that I'd need to use some kind of belt drive to keep the motor as far as possible from the CRT.
Ummon
« Reply #7 on: October 30, 2009, 05:09:33 pm »
Look into what people have done. And google motorized systems - amps relative to torque and stuff.
Yo. Chocolate.
Stephen Hawking
