Author Topic: Control Panel help.  (Read 1902 times)
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
Control Panel help.
« on: October 19, 2009, 01:42:49 pm »
I have a Tekken 4 machine in a Blue capcom Dynamo cab with the following issue. When ever I push up on the joystick, whether it's the 1p or 2p side BOTH characters move up. This issue only happens when pressing up, all other functions work properly. I swapped out PCBs and its the same issue. I inspected both micro switches and they are NOT connected to each other in any way. The edge connector for the Jamma harness looks fine as well....Any ideas?
XBL:Mykungfooizgood
PSN: Mykungfooizgud
SirPeale
  • Green Mountain Man
Re: Control Panel help.
« Reply #1 on: October 19, 2009, 04:35:51 pm »
Occam's Razor - there's got to be a bridge somewhere.  Double check the wiring again.
Oni2382
« Reply #2 on: October 19, 2009, 05:43:43 pm »
OK I will double check....Could there be a possible bridge in the ground wires??
XBL:Mykungfooizgood
PSN: Mykungfooizgud
SirPeale
« Reply #3 on: October 20, 2009, 05:42:24 am »
That would be fine. Grounds are all connected anyway.  No, it's got to be something else.
SirPeale
« Reply #4 on: October 20, 2009, 05:44:14 am »
Here's the JAMMA pinout
http://www.pealefamily.net/tech/jamma.html
Check your harness carefully.
