Author Topic: Daphne FrameFiles?  (Read 6356 times)
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
Daphne FrameFiles?
« on: July 16, 2003, 05:38:25 pm »
i got some daphne stuff and im tryin to figure out whats this framefile thing its not in the rom or anything anyone have an idea or where i can get it [im guessing its part of daphne, its this is considered a rom request please ignore]
anyways i cant get space ace or dragonlair to run it says i need that part of daphne i guess framefile.txt
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
Re:Daphne FrameFiles?
« Reply #1 on: July 16, 2003, 06:37:46 pm »
The framefile can be whatever yoyu want to call it, one for each MPEG set, usually in the Daphne framefiles folder.
They are generally included with the MPEGS.  You specify the name of the framefile either in the Daphen Loader config screens or in your command line if you prefer.
The most common framefile will be in this format
<line 1 - specify the path to your MPEG file>
c:\daphne\mpeg\lair
<line 2 - specify the frame number and corresponding MPEG file name>
1     Lair.m2v
As I say that is the most common and applies generally when you only have one m2v file.  Some MPEG sets are broken into several M2V's so you need a framenumber for each file.
Google around, you will find the usual framefiles quite easily.  Or if you only have one M2V as above, make them yourself.
Jakobud
  • Last login:May 25, 2026, 02:04:14 am
« Reply #2 on: July 18, 2003, 05:35:06 pm »
You need to read the info on daphnes website regarding framefiles. if you are downloading mpegs, they should have framefiles with them.
Syxx
  • Bling Bling
« Reply #3 on: July 18, 2003, 06:04:14 pm »
ya i created one, thanks everyone got it figured out.
