Author Topic: Topgun2 trigger breaks after 6 months. Help Needed  (Read 1932 times)
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
« on: October 07, 2009, 06:15:56 am »
I will pull the gun apart in the next couple of days and see if it is repairable but the trigger stopped working in the middle of a heated session of BBH- 3 players. OK the gun has had some work - BUT- its in a home use situation. Not good enough. I had read these guns can't take regular use on this forum and it looks like that advice was correct. I was using the gun at the time and got a distinctive click like a spring breaking. The return on the trigger stiil works but it does not register.
Anyone else fixed one yet?
« Last Edit: October 08, 2009, 04:53:32 am by swamprat96 »
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
Re: Topgun2 trigger breaks after 6 months. Go AimTrak
« Reply #1 on: October 07, 2009, 08:24:03 am »
One of the bad thing of LCDTopGun is that they don't use microswith for the trigger. Insteas, it has a conventional gamepad switch.
So you could open the gun and change this button. This is what I did for one of my LCDTopGun...
swamprat96
« Reply #2 on: October 07, 2009, 07:27:51 pm »
Thanks Cananas. Are the guns easy to open? And when you say a conventional game pad switch- got a link to a picture
swamprat96
Re: Topgun2 trigger breaks after 6 months. Need disassemble help
« Reply #3 on: October 08, 2009, 12:12:11 am »
I'm having trouble getting this thing apart. I've removed all the screws I can find and the handle grips plus the sliding breech but it does not want to open. I've searched the forum and I know someone has done this- anyone?
see the photo. The red circles are the screws I have removed. The blue circle is some kind of tab I think I need to release
« Last Edit: October 08, 2009, 12:49:44 am by swamprat96 »
Cananas
Re: Topgun2 trigger breaks after 6 months. Help Needed
« Reply #4 on: October 08, 2009, 06:14:55 am »
There is one more hidden screw here:
swamprat96
« Reply #5 on: October 08, 2009, 03:12:33 pm »
thanks again cananas
