Author Topic: matsushita tm202g  (Read 2557 times)
jb6626
  • Last login:December 08, 2009, 12:51:49 am
matsushita tm202g
« on: October 06, 2009, 11:18:58 am »
I have a matsushita tm202g mounted vertically in a millipede cabinet.  After warm up (2-5 minutes) the picture begins to warp from top to bottom and then rolls in the same direction.  No adjustments help the problem.  I have replaced every cap on the chassis along with the IC.  Even after the warping the game plays in the blind.  I was told I have a sync problem but don't know how to fix or adjust that issue.  Any help or ideas will be appreciated!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: matsushita tm202g
« Reply #1 on: October 09, 2009, 06:55:24 pm »
schematic here: http://pdf.textfiles.com/manuals/ARCADE/SMALLFILENAME/tm202g.pdf
posting a pic might help  ;)
meanwhile, verify that the Vreg circuit is regulating....
and checked/replaced c454, c451,c452,c455,c310
jb6626
« Reply #2 on: October 12, 2009, 03:39:40 pm »
Talked to an arcade tech that was familiar with this monitor and its problems.  He said the cap at C805 was factory at 33mF@160v and over time it caused sync problems and if changed to 33mF@250v the problem would be corrected.  That cap was changed when I recapped the chassis but was a 160v cap.  I changed it to 33mF@250v and the sync problem was gone.  After adjustments for color, focus and position it's better than a new monitor.  After some cosmetic work another game will be saved from the junk pile.
