Author Topic: check out these switches  (Read 1299 times)
paigeoliver
  • Awesome face!
« on: July 16, 2003, 01:40:45 am »
http://www.channelbeat.com/products/parts/pump_it_up_parts/150.html
Are these the switches underneath the arrows on dance pads? Or do they have something else entirely?
I know they are supposed to have "membrane switches".
Or is it these?
http://www.channelbeat.com/products/parts/dance_dance_revolution_parts/115.html
Or are both of those basically the same thing?
And if so, then is there a cheaper source?
Unfortunately if I want a good pad then I am going to have to build, because no one seems to sell metal "Pump it Up" pads and I can't even find a source for used originals. Kind of wish I would have gotten into DDR instead, since that stuff is much easier to find.
There is always the last resort of buying a 51" Korean Import Pump it Up machine for $2800. I imagine I would get near half that back selling the guts out of it (leaving me with the cabinet, the 51" monitor, the pads and speakers, and I could just run StepMania in it, as it is better than the REAL PIU anyway).
« Last Edit: July 16, 2003, 03:29:09 am by paigeoliver »
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
Re:check out these switches
« Reply #1 on: July 16, 2003, 11:07:58 am »
Build a Pad!  Its fun, and is cheaper than buying a metal pad.
I used the plans from http://www.geocities.com/ddrhomepad/ and just finished on the weeked (I'll put up pictures whenever I get around to borrowing a digital camera again).  You don't really need switches if you use this design.  It uses two big (9"x9") pieces of sheetmetal for each arrow that are separated by a 1/4" and when you step on the arrow, the top sheet makes contact with the bottom sheet and completes the circuit.  You don't even need to hack a controller if you have an arcade cabinet, you can use your keyboard interface without any problems.
I really suck at DDR, but its something different and kind of fun.  The wife likes it too (though she is even worse at it than I am).
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
« Reply #2 on: July 16, 2003, 05:26:00 pm »
What are you using to play DDR?  Is there a PC version?
oh man I thought I was done with this!!
this and that crazy "Pop and bounce" game from the the everything forum.
ny
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
« Reply #3 on: July 16, 2003, 05:30:25 pm »
yes there is a DDR version, I've seen it in Fry's
