Author Topic: I toasted my 8liners chassis. Trying to repair.  (Read 2829 times)
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
« on: September 27, 2009, 11:50:04 am »
About 2 or 3 months ago I got a wei-ya 1220h from 8liners and
connected it to an old t.v. tube.
I didn't have a working isolation transformer at the time and thought
that it probably needed one, but I decided to try it out anyway without one.
It worked fine for a couple of hours untill the bottom half of the picture
started sucking up toward the center of the tube and shortly after suffered
what I think may be vertical collapse where the entire vertical portion of the
video display had condensed into a single horizontal line through the center
of the tube.
I looked over the chassis and nothing seemed to be obviously toasted
so I just assumed that the video processor IC HA11235 was fried.
I just got around to ordering another yesterday along with an isolation transformer.
Is there anything else on the chassis that I should replace, or should I
wait and see if the new IC remedies the problem first?
Trample the weak, hurdle the dead
Ken Layton
  • Guru
  • Technician
Re: I toasted my 8liners chassis. Trying to repair.
« Reply #1 on: September 27, 2009, 12:37:34 pm »
Yes the 1220H REQUIRES an isolation transformer. It also uses a "low impedance" yoke.
The IC you mentioned would likely NOT be the problem. You'd want to look at the "vertical output" IC instead. They usually have an "LA-78xx" part number on them and are bolted to a big aluminum heat sink to dissipate the heat.
M.Lanza
« Reply #2 on: September 27, 2009, 12:59:37 pm »
Alright, Thanks.
I guess I'll be on the lookout for a LA7833 then?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 27, 2009, 01:05:00 pm »
Yes that is correct. MCM Electronics has it and I think Bob Roberts should too.
That IC crosses to an NTE 1773 also.
M.Lanza
« Reply #4 on: September 27, 2009, 01:47:24 pm »
I just finished ordering one.
I guess I should have asked before ordering the other one.
At least it didn't cost too much.
TOK
  • Last login:Yesterday at 11:59:04 am
  • The Game Always Wins
« Reply #5 on: September 28, 2009, 08:25:16 pm »
That was my first major arcade screw-up. I had an old monitor out of a Karate Champ with a hacked up harness.
I rigged up a cord directly from the wall to test it out. Mine didn't last as long as yours though, in fact, it lasted about 5 seconds before emitting a huge flame a cloud of acrid black smoke.
My garage stank for hours.  :lol  :cheers:
M.Lanza
« Reply #6 on: October 02, 2009, 08:35:59 pm »
I guess as long as I learn something, it was worth it.  :cheers:
I just changed out the la7833 and nothing has changed.
I really don't know what I'm doing, I'm going to pull out the chassis
again and swap the HA11235 and see if that helps.
Ken Layton
  • Guru
  • Technician
« Reply #7 on: November 20, 2009, 10:46:17 pm »
It could have internally damaged a resistor, capacitor, diode, or transistor from not using the isolation transformer.
