Author Topic: WG 25K7197 with 6-7" vertical sweep  (Read 1945 times)
Mike Johnston
  • Newbie
  • Last login:September 30, 2009, 04:41:43 pm
« on: September 25, 2009, 02:07:47 pm »
Hello. I have a Wells Gardner model 25K7197 in a Big Buck Hunter conversion cabinet.
Symptom:
The vertical sweep has collapsed ( after a move ) to about 5 to 7 inches and has a slight wave.
The vertical size adjustment and the VR9 have very little effect.
Things I have done:
I installed all 17 electrolytic capacitors from Lizardlick Amusements ( no change ).
I replaced DC blocking capacitor C50 ( no change ).
I re-soldered the CRT socket on the neck card ( long shot, no change ).
Can  you make any suggestions ?
I have a schematic.
Other than a VOM I do not have any test equipment.
Mike J.
Kevin Mullins
    • Me on Myspace
Re: WG 25K7197 with 6-7" vertical sweep
« Reply #1 on: September 25, 2009, 02:25:59 pm »
As with any K7000, check the chassis carefully for bad solder joints and traces that may have lifted and crack especially around large resistors and such.
Check for +24v at IC3, check R91.
Replace IC3
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: September 26, 2009, 10:19:03 am »
closely inspect the vert yoke connections. i.e. look for a broken wire.
the vertical windings are two identical coils wired in parallel.
when either side is open, the symptom is what you posted...
hopefully , it will be a single break and easily patched.
with multiple breaks , just replace the yoke  ;)
