Author Topic: NTFS or Fat32 on Win2k MAME Machine?  (Read 2635 times)
ArcadeFX
  • Last login:November 10, 2004, 11:16:56 pm
  • All the Dude ever wanted was his rug back!
    • ArcadeFX
« on: February 26, 2002, 09:31:53 pm »
I am not going to be running any other favors of windows or dual booting.  Does MAME run better on one of the other?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: NTFS or Fat32 on Win2k MAME Machine?
« Reply #1 on: February 26, 2002, 09:41:35 pm »
ntfs in win2k is probably better.  My guess...
JMDickson
  • Last login:October 21, 2011, 11:22:48 pm
« Reply #2 on: February 26, 2002, 09:43:18 pm »
The tradeoff usually is a result of cluster size.  The way MAME uses files, it will not gain anything from NTFS features.  In fact it loads the data once, and is done with it, so you won't see much if any difference.  The size of the partition will probably be the best guide.
If you 'need' to collect every MAME rom, you will end up with a lot of wasted space if you have a large partition.  NTFS can help this a little if you force small cluster size, but this will also slow performance a little.
ArcadeFX
    • ArcadeFX
« Reply #3 on: February 26, 2002, 09:49:36 pm »
Well, I just went with Fat32 but my drive is a full 38GB.  I should probably convert this to NTFS just for that reason.
I can do this right from Win2k right?  I am pretty sure I did this once before but can't remember.
SirPoonga
  • Puck'em Up
« Reply #4 on: February 26, 2002, 11:13:43 pm »
Though fat32 couldn;t handle over 32gigs.
Yeah, in your computer manager you can change it
Lilwolf
  • Last login:Yesterday at 06:33:59 pm
« Reply #5 on: February 27, 2002, 07:57:45 am »
Win32 was nice since you could have a win98 partition talking to it.
But NTFS is faster, nicer, more stable, and has a great feature of you specifying if a directory as compressed (you can run everything from it, but it will compress/decompress them for use)
But I use win32 since I have a 98 boot partition also
Lilwolf
« Reply #6 on: February 27, 2002, 07:58:35 am »
Bigger question.
WHY IN THE 1@#% ARE YOU USING WIN2K?
It really sucks for mame.  Go with XP or 98.  You will probably double your fps!
ArcadeFX
    • ArcadeFX
« Reply #7 on: February 27, 2002, 08:06:08 am »
I don't have a copy of win98 but I do have one of XP.  Any problems with running most PC games on XP?  Castle Wolf, NFL Blitz are two that I will be installing.
Blake
  • Last login:Never
  • Go MAME!
    • My MAME Cab
« Reply #8 on: February 27, 2002, 08:09:28 am »
Really??  I'm using Win2k on my machine for the stability and I haven't noticed any FPS problems at all.  But I am thinking about going back to Win98 due to DOS compatability problems - can't run Dragon's Lair CD-ROM version or Golden Tee Golf.  And I don't really see the need to spend $100 for XP to play them...
Bigger question.
Lilwolf
« Reply #9 on: February 27, 2002, 08:15:25 am »
I have a 800mhz athlon at the office running a decent video card.  I can't have a single option (triple buffer, scan lines, or anything) to get them to run.
At home with a 1ghz athlon (sure a little faster) I can get almost every game to run with every option on.
NT/2000 was never considered a game system at all and wasn't designed for it.  XP was really designed to be good for both developent and game playing
ArcadeFX
    • ArcadeFX
« Reply #10 on: February 27, 2002, 08:26:04 am »
Going with 98 as soon as I can find a copy.  Thanks.
pink
  • Last login:March 19, 2007, 11:57:58 pm
  • Your phone's ringin dude.
« Reply #11 on: February 27, 2002, 08:48:28 am »
lilwolf - if you have a huge difference between frame rates between 2k and xp, the prob is your machine or your config on the 2k machine, not win2k itself.
As for ntfs/fat32, you wont notice a performance difference, the advantage of sticking with win32 is you can access the partition from a 98 machine and troubleshooting / recovery is a lot easier if you wind up having a system crash.  (However the likelyhood of that is less with ntfs, so its a 6 - 1/2 dozen thing)
- pink
Lilwolf
« Reply #12 on: February 27, 2002, 09:05:17 am »
my systems are 98 and 2000.  And I've seen a HUGE difference between games..
but I can also say this.  EVERY development system I've ran runs SO MUCH better on 2000 on similar hardware.  I really believe that it's the DX implementation on 2000 sucks... and 98 sucks for everything else
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
Re:NTFS or Fat32 on Win2k MAME Machine?
« Reply #13 on: January 31, 2004, 09:24:59 am »
*bump*  ;D
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #14 on: January 31, 2004, 09:36:20 pm »
Its rarely straightforward - as it will depend on your system components. For example, some video cards have drivers with completely different performance in 98/2k/XP - even for quite basic functions (i.e. 2D) that mame uses. Gaming cards can sometimes have lacklustre 2k drivers as driver developers assume it is less important.
It can be more complicated though - win98 allows programs much more direct access to hardware (which is faster) than 2k/xp which keep tighter reigns on programs to reduce crashes. This extra layer can sometimes rely on drivers by the likes of SIS, INTEL, ALI or VIA depending on the chipset on a motherboard and performance can vary. Some chipsets had horrendous performance under a different OS (eg early VIA drivers) - and even if updated drivers improve things people often miss getting them as they are not graphics drivers and they don't realise to look for them.
Also, 2k/xp are definately more resource (memory/cpu) hungry than 98 - so for example someone with 64mb or 128mb of ram may find that performance in 98 is great, but crippled when using 2k on the same pc. However - if they had 512mb, they may find performance extremely similar between 2k/98 - and thus choose 2k for stability.
To get back to the original post question - if you are worried about this simply because of mame performance, don't be. Otherwise its a size of HD/other features type of question.
(Apologies for some glaring technical simplifications to try and get a point across! ;))
GroovyTuesdaY
  • Last login:June 07, 2005, 03:22:18 am
  • "Follow the white rabbit! ....KNOCK KNOCK NEO...."
« Reply #15 on: January 31, 2004, 10:59:03 pm »
Generally speaking, windows XP is a much better and more stable platform then 98 or millenium.   Even though i miss palying some older games like star wars ROGUE SQUADRON, i have really seen not one single benefit to using anything other than windows XP.  Its memory managing is tons better and i rarely IF EVER have it just crash for no reason.   Unless your using your rig in a DOS mode for your
 cabinet, then go with windows xp.  I'm sure there are still  ways to use mam32 without worrying about people monkeying with stuff if you have others play on your setup.  Just check in these forums some advice from others who have tried different front ends and the like.
Dos drivers are getting harder and hard to find also and windows 98 if im not mistaken is not even supported by microsoft anymore, so its a forgone conclusion really.......its time to let the old operating system die.  :'(  lol
groovY~
In the mighty words of the BEE GEES im-
"STAYIN' ALIVE, STAYIN' ALIVE!"
hehehe
