Author Topic: Remove coverup?  (Read 1604 times)
rwhite
  • Last login:December 26, 2011, 11:20:56 pm
Remove coverup?
« on: September 24, 2009, 07:27:03 am »
Hi, first post and so glad to be here and finally starting cabinet.
I am working with 2 player X-MEN cab that had been converted. Side art had been covered with a shiny embossed material. Working carefully with a hair dryer left side stripped off  in a couple hours, art work is in almost perfect shape a definite keeper! The cover up on the right side is much tougher to remove with the same method, have moved up to a real heat gun (adjustable) and have tried a couple of gentle solvents even vinegar (like wallpaper remover)
The adhesive here is so strong, I only have a very small patch removed. Anyone seen this stuff before? What else might work here?
garnerb350
    • Hyperspin
Re: Remove coverup?
« Reply #1 on: September 24, 2009, 08:43:58 am »
Would lighter fluid work? :dunno I was wondering if you can pull a piece up...take the lighter fluid and squirt it where you can lift up and pull away ( one big piece)...The arcade I worked at when i was a kid, we used to take lighter fluid and use it to clean gunk on any of the cabs...
rwhite
Re: Remove coverup?
« Reply #2 on: September 24, 2009, 09:57:48 pm »
O.K. garnerb! The lighter fluid slowly started to melt the vinyl(?) it told me yes -  this wants to be done chemically. I didn't want to do it but I broke out the big guns, lacquer thinner and acetone. I just stumbled out of the cellar and the job is done. Thanks man!
garnerb350
    • Hyperspin
Re: Remove coverup?
« Reply #3 on: September 25, 2009, 08:21:03 am »
Rwhite....glad to hear everything worked ok...
Yeap i'm working on restoring an old Mr Do cab and I used it regulary...what you can do also is take it and let it sit for a couple of min ...and it will allow you to wipe that side clean...
