Author Topic: My monitor swap...success w/pics  (Read 1753 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: September 23, 2009, 10:47:11 pm »
My tube swap worked out.  In all honesty it wasn't that tough after all.  It was actually tougher to find the tube than the board.  This one came out of a Phillips tv.  A little work and all should be well.  Here's what I got.
Here's the original, also a Phillips tube.  Unit had so much burn in that you could read it across the room.
The connectors weren't the same.  Good thing I had wire cutters
This is the back of the tube and chassis after I spliced in the connectors.
Here's the tube with the old chassis.  They don't fit.  Going to have to make a new holder.
That's where this all comes in.  Jigsaw here I come.
Here's the new, swapped tube looking good.
Lessons learned:
You can swap a 20 inch tube to a 19 inch chassis.  However, I've never tried this with a different mfg'r.  I figure it's probably safe if you use the same make but I wouldn't chance it.
Connectors need to be swapped.  I used crimps.  I'm sure solder will wok as good if not better.  The problem is that one monitor had stranded wire and the other had single wires.  I didn't want to desolder it because it was a serious mess.
Unlike what has been said in other places, I was able to keep the original yoke.  You'll see that the pics show the convergence is alright.  I mainly kept the yoke becuse the neck of the tube was a different diameter.
That said, it worked and I'm satisfied.  I just need to cut myself a new mount out of particle board and I'll be happy.  Will post pics of the DD restore later.
smalltownguy
  • Last login:February 27, 2026, 07:59:15 pm
Re: My monitor swap...success w/pics
« Reply #1 on: September 23, 2009, 11:21:11 pm »
Hurry up with the DD restore pics! I LOVE that game. I owned it for a bit, until an arcade owner approached me to put it back into service at his location. I couldn't help but sell it, if nothing else, she's back where she belongs -- in an arcade. Now I go visit her every now and then to pay homage  :P
iscariot
« Reply #2 on: September 23, 2009, 11:52:15 pm »
Actually, I need some stuff, IE the sideart(the boring taito stuff), the CPO(the original was silk screened), bezel and the marquee.  It looks like the cab was in a windows or something.  It looks horribly sun bleached.
