Author Topic: Mame question  (Read 3355 times)
(+_+)
  • Let me splain.
  • Last login:July 27, 2012, 09:00:32 pm
  • For I am ]{eyser Soze
Mame question
« on: September 23, 2009, 11:39:36 am »
Does anybody know if there is a Mame switch that will allow you to select what monitor you'd like to run a game on if you have a dual monitor setup?
This plan is so perfect, it's retarded. -- Peter Family Guy
Beretta
Re: Mame question
« Reply #1 on: September 23, 2009, 11:53:39 am »
there is but im not sure exactly what it is since i've never used it.
check the mame.ini there are a bunch of video settings in there.
also you can do mame -showusage at the command line to spit out a bunch of configuration options.
this is probably what you want here..
"-numscreens          number of screens to create; usually, you want just one"
but there are more video options as well.
-screen              explicit name of all screens; 'auto' here will try to make a best guess
-aspect              aspect ratio for all screens; 'auto' here will try to make a best guess
-resolution          preferred resolution for all screens; format is <width>x<height>[@<refreshrate>] or 'auto'
-view                preferred view for all screens
-screen0             explicit name of the first screen; 'auto' here will try tomake a best guess
-aspect0             aspect ratio of the first screen; 'auto' here will try to make a best guess
-resolution0         preferred resolution of the first screen; format is <width>x<height>[@<refreshrate>] or 'auto'
-view0               preferred view for the first screen
-screen1             explicit name of the second screen; 'auto' here will try to make a best guess
-aspect1             aspect ratio of the second screen; 'auto' here will try to make a best guess
-resolution1         preferred resolution of the second screen; format is <width>x<height>[@<refreshrate>] or 'auto'
-view1               preferred view for the second screen
-screen2             explicit name of the third screen; 'auto' here will try tomake a best guess
-aspect2             aspect ratio of the third screen; 'auto' here will try to make a best guess
-resolution2         preferred resolution of the third screen; format is <width>x<height>[@<refreshrate>] or 'auto'
-view2               preferred view for the third screen
-screen3             explicit name of the fourth screen; 'auto' here will try to make a best guess
-aspect3             aspect ratio of the fourth screen; 'auto' here will try to make a best guess
-resolution3         preferred resolution of the fourth screen; format is <width>x<height> [@<refreshrate>] or 'auto'
-view3               preferred view for the fourth screen
severdhed
  • RIP Dinosaur Hippo
Re: Mame question
« Reply #2 on: September 23, 2009, 12:05:28 pm »
i did this a while back, but i forget how.  i dont have multiple monitors on my pc here at work, i'll try to look when i get home if i remember.
Burke LaShell
  • Last login:October 10, 2015, 06:45:05 pm
Re: Mame question
« Reply #3 on: September 23, 2009, 12:33:31 pm »
I use this...
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10106&cs_id=1010602&p_id=246&seq=1&format=2
...to connect two PC (MAME and Jukebox) to the flatscreen monitor on the wall.
Would that work for you?
Ginsu Victim
  • Last login:May 15, 2026, 12:35:01 am
  • Comanche, OK -- USA
Re: Mame question
« Reply #4 on: September 23, 2009, 12:34:52 pm »
^You've got the wrong idea.
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Mame question
« Reply #5 on: September 23, 2009, 12:48:25 pm »
Small note: if you enable -verbose, mame will output the name(s) of the monitor(s) used to the command line.  It'll be like the first or second line.
example of my work monitor:
Parsing mame.ini
Video: Monitor 00010001 = "\\.\DISPLAY1" (primary)
Direct3D: Using Direct3D 9
Use this info with the -screen option(s).
Robin
Knowledge is Power
(+_+)
  • Let me splain.
Re: Mame question
« Reply #6 on: September 23, 2009, 03:26:31 pm »
u_rebelscum,
As in
mame galaga -screen \\.\DISPLAY2
I'm going to need this info for my next cab incarnation to work the way I'd like it to.
My Horizontal/Vertical Arcade/Pin Cab. It's in the mental design phase.
An exact command would be much appreciated.
garnerb350
    • Hyperspin
Re: Mame question
« Reply #7 on: September 23, 2009, 03:57:31 pm »
There has to be way...I guess, because they mamed Punchout(2 monitors) and Ninja warriors (that had 3 monitors) and i know there are more...
