Author Topic: Arcade Monitor To PC  (Read 2371 times)
Luige11
  • Last login:December 16, 2009, 11:49:40 pm
« on: September 20, 2009, 06:26:37 pm »
After a few months of having the same game in my machine I decided to mame the sucker  :laugh:. Turns out I have a Arcade VGA card laying around my house and nobody is using it so I decided to put it to use! Now I have a problem I pulled out my machine to look at the connector on the back of the monitor its like 2 squares together and I have no idea how plug it into the VGA card. Theres no slot for it so I think I need an adaptor for it but have no idea where to buy one from. Thanks for your help!
Luige11
Re: Arcade Monitor To PC
« Reply #1 on: September 20, 2009, 06:35:10 pm »
Heres some pictures
phatmeat
  • Last login:May 25, 2013, 12:08:55 am
« Reply #2 on: September 20, 2009, 06:39:57 pm »
Those be the power connectors..... You can just get and old vga cable and cut it up.. or get one with an amp form ultimarc http://ultimarc.com/JShopServer/section.php?xSec=2
 The connection you want is right on the monitor chassis
Luige11
« Reply #3 on: September 20, 2009, 06:42:30 pm »
Wow do I feel stupid. Ill reopen it and give it a look.
Luige11
« Reply #4 on: September 20, 2009, 06:53:44 pm »
Well I opened it now and im looking at the monitor chassis but I don't see a connection simmilar to the vga card
phatmeat
« Reply #5 on: September 20, 2009, 07:05:53 pm »
follow where those other wires in that harness go. It will most likely no have a std vga connector .
Luige11
« Reply #6 on: September 20, 2009, 07:25:21 pm »
Instead of going thru the hassle of getting the extra 4 volts that the arcade vga card doesnt supply im better off using a flat screen
