Author Topic: MAME key mapping issue  (Read 955 times)
VespaGuy
  • Last login:July 06, 2022, 09:47:28 pm
« on: September 20, 2009, 12:26:22 pm »
The other day, I let my friend's son play with my arcade machine. Like most kids, he made it a point to press every combination of buttons possible and I noticed that he had accessed at least one of the admin menus. I got him out of the menu and kept a closer eye on him after that. But this morning, I turned on my machine to find a small problem: While a game is open, if I press the Player 1 Start button, the game will start, but the volume/gamma dispay pops up on screen also (pressing Player 1 Start button again will remove the volume/gamma display).
Here's what I've figured out so far:
- I disconnected the Player 1 "up" wire from the I-Pac to see if there was a short. (The player 1 start button is my "shift" button and the "up" button's shift command is "~", which should bring up the volume menu). Without anything connected to the "up" input on the Ipac, I still get the volume menu when I press Player 1 Start.)
- I opened notepad and press player 1 start. It types "1", and not a "~".
With those two things in mind, I'm assuming that the problem is not with the electronics.
My guess is that somehow the mapping got changed and that player 1 start is now mapped to the volume control, but I'm not sure where to find this info or how to change it back. Any suggestions?
Thanks in advance!
tomdotcom
  • Last login:March 05, 2014, 11:55:56 pm
Re: MAME key mapping issue
« Reply #1 on: September 20, 2009, 12:34:13 pm »
Did you check the settings in the tab menu? Maybe the volume is just changed to 1 in there instead of ~.
=-= Pins: Fishtales, Bram Stoker's Dracula, Revenge from Mars, Skateball =-=
=-= Custom Mame cab =-=
VespaGuy
« Reply #2 on: September 20, 2009, 03:45:46 pm »
That's probably what happened. I ended up just deleting the default.cfg file and it's working fine now.
