Author Topic: t-molding  (Read 972 times)
Uncle Monkey
  • Last login:September 12, 2020, 10:16:25 pm
  • P24L
    • Project Thread
t-molding
« on: September 18, 2009, 12:33:55 am »
can anyone tell me about how many feet I need to do an entire mameroom cab?
Re: t-molding
« Reply #1 on: September 18, 2009, 12:47:37 am »
2 feet (unless you've got a peg leg) Bad ooomp....  pahhh  :lol
Seriously though, typical cab about 6 feet high, 3 ft deep, little less than 3 ft wide
So that's 6+6+3+3+3=~21
if you go all the way up the front, down to the back on the top, then across on the CP.
If you want to put more tmold on (trim the whole CP, or run tmold down the sides of the CP as well) or if you're cp is extended like a 4player, or your putting lit cutouts on the sides, you'll need more.
I'd guess 30ft would likely be plenty, and 40ft would be way more than you'd need, but you'd be safe.
Sometimes you can get remnants for a little cheaper too. I bought a bunch of black leather texture tmold that way, came in 2 20ft "scraps".
churchpunk1123
  • Last login:September 19, 2009, 01:38:26 am
Re: t-molding
« Reply #2 on: September 18, 2009, 04:16:02 pm »
You should measure all of the sides... It really depends on how many edges you have to cover.  After you measure add about 4 feet to that for mistakes/replacement/insurance.
shardian
Re: t-molding
« Reply #3 on: September 18, 2009, 04:54:46 pm »
I steal my wife's seamstress tape measure for T-molding measurements.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: t-molding
« Reply #4 on: September 18, 2009, 04:59:45 pm »
If your cab is not rectangle, or has lots of curves, a string might be easier than a tape measure.  Lightly wrap the string around wood were you want the t-molding, then measure the string.  Just don't wrap the string tightly and then measure the string un-stretched.
Edit: or the shardian side
Robin
Knowledge is Power
