Author Topic: DIY VGA gender changer?  (Read 6907 times)
Franco B
« on: September 16, 2009, 05:40:00 pm »
I want to connect my 360 to a VGA monitor (not my work one, honest guv ;))
I have a 360 VGA cable but the monitor does not have a VGA port, it has a VGA lead hard wired to it. I was going to buy a F/F VGA gender changer like this to connect both cables to:
However, I have some 15 pin female d-subs. Would I be able to make my own by wiring up two of these?
I presume I would just wire pin1 on one d-sub to pin 1 on the other etc etc? Do all 15 pins need connecting?
Franco B
Re: DIY VGA gender changer?
« Reply #1 on: September 16, 2009, 07:32:15 pm »
Damn it, just realised the 15 pin d-subs I have are two rows (8+7) rather than the VGA connection (5+5+5)  :timebomb:
Looks like i may have to buy one. I don't think I can pick up some VGA d-subs locally.
Do you think [this] would work? (the F/F version.)
« Reply #2 on: September 16, 2009, 08:53:19 pm »
I played with making my own VGA connectors at one point, but you have to get the joints soldered very well and keep the wires neat or you'll get interferance and a terrible picture.
The dsubs you have with 8/7 are serial port or old CGA adapters.
I probably have a 15pin vga adapter around here somewhere if you need it.
MonMotha
« Reply #3 on: September 16, 2009, 09:11:33 pm »
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10416&cs_id=1041601&p_id=1172&seq=1&format=2
and...you're done.
Yes, you can make one yourself.  No, you don't have to be nearly as careful as described.  Over small distances, signal integrity isn't really much of an issue even at rather high resolutions.  But, you know what?  It's still a pain in the butt, and the result is a lot more fragile than the nicely molded commercially made ones.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #4 on: September 16, 2009, 09:50:00 pm »
and...you're done.
I second that.  Shipping will be under 2 bucks and pretty quick.  Monoprice is awesome for little things like this.
Ginsu Victim
  • Last login:June 29, 2026, 04:15:57 pm
  • Comanche, OK -- USA
« Reply #5 on: September 17, 2009, 10:34:11 am »
Don't Google "gender changer"
Especially the image search.
Franco B
« Reply #6 on: September 17, 2009, 06:00:09 pm »
I did actually Google image search to find that picture above. It's a good job I had VGA in there too though!  :D
Thanks for the advice and also the offer drventure.
Being impatient and wanting to play some xbox tonight I got a buddy of mine to pick one up for me from Maplins for £8, ouch! I actually realised afterwards that I have a VGA switch which would essentially do the same thing, doh!
For the audio the only speakers I have on my workbench are in a crappy radio cassette so I had to go VGAs RCA>RCA-3.5mm jack adapter>3.5mm F/F coupler>one of those cassette tapes with a 3.5mm jack
Anyway, the switch worked fine. At least I can take the gender changer back, knowing me though it will probably sit in a draw forever  ::)
massive88
« Reply #7 on: September 18, 2009, 12:07:33 pm »
To reply to your original question, at least in part, you only need 6 wires, those that would correspond to component out signals.
For a while I had my own rigged Component-Cat5-VGA cable for my projector, using something similar to this - http://www.geocities.com/dougburbidge/vgaovercat5.html
Franco B
« Reply #8 on: September 18, 2009, 02:42:31 pm »
Thanks for the info massive88. I'll keep that in mind for future reference.
