Author Topic: Electrohome G07CB0 crack in the neck tube.......is this bad?  (Read 1822 times)
MaineEvent
  • Last login:September 10, 2015, 07:45:33 pm
« on: September 11, 2009, 11:43:34 am »
Before I continue to buy parts to repair my chassis, I wanted to know if the crack in the neck tube says I should forget it.
The crack has been there since I have owned the cab and it did work nicely for me for a bit....now I think I have a regulator problem ( see http://forum.arcadecontrols.com/index.php?topic=95063.0 )
Also the last time I turned on the cab, there was no visible glow from the neck tube.
What do you guys think?
My Games:
Arkanoid
Ken Layton
  • Guru
  • Technician
Re: Electrohome G07CB0 crack in the neck tube.......is this bad?
« Reply #1 on: September 11, 2009, 12:55:32 pm »
That does not appear to be a crack. Looks like a fine hair of some glue. Scrape it off with your fingernail.
MaineEvent
« Reply #2 on: September 11, 2009, 01:09:45 pm »
WOW!
Thanks again Ken!
You are truly an Arcade Wizard :notworthy:
*Sigh of relief*
Thank you
My Games:
Arkanoid
Kevin Mullins
    • Me on Myspace
« Reply #3 on: September 11, 2009, 08:52:37 pm »
 :laugh2:
Sorry..... had to get that out.
But always good to find out it's NOT what you think it is in this case.
If it had been a crack, you would have known.... it puts off a nice little light show in the neck.
