Author Topic: Hard Drive Based Spinners  (Read 1780 times)
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
« on: July 13, 2003, 11:06:00 pm »
I'm building a hard drive based spinner.  I found a perfect knob off of an old exercise bike.   It has a 1/4" shaft hole with a bolt to hold shaft in place.
I took apart and old 1.2 gb Westerdigital IDE Hard drive.  I am using the bearing from it.. The hole on the top of the bearing, seems to take a 2mm screw.
So my question is where can I find something that has a 2mm screws .  Maybe if I found a long 2mm screw I could put 1/4" spacer on it.  I check home depot and radioshack but no luck.  I will be hitting the smaller electrical shops in town.
Any Ideas,
Off all the things I've lost I miss my mind the most!!
nighthawk2099
  • Last login:June 10, 2015, 04:01:16 pm
  • I LIKE TATER-TOTS!
    • IRONMAME
Re:Hard Drive Based Spinners
« Reply #1 on: July 14, 2003, 08:52:41 am »
Go to Lowes and there is a section where they have all of the screws (hehe-- I said screw...) anyway, they have small threaded studs about 4 inch long and about 2mm (large range of sizes).  Just take the drive parts and the knob and size stuff out.....
aricade
    • Isaacade
« Reply #2 on: July 14, 2003, 12:21:05 pm »
 :'(Unfortunatley I'm in Canada.  Ottawa to be specific.  We dont have a Lowes here(at least in Ottawa at any rate).
Anybody know of a store with similar stuff  in canada, particularily ottawa, ontario.
TY
CanStick
  • Last login:May 02, 2004, 12:39:58 pm
    • CanStick Controls
« Reply #3 on: July 14, 2003, 12:31:57 pm »
TY
Hi there,
The thread in the top of the WD hard drive is a #4-40 thread (at least it was in the WD hard drive I took apart one time).  They are pretty common...you can get them at Canadian Tire in a small pack pretty cheap.
Hope this helps!
Terry.
aricade
    • Isaacade
« Reply #4 on: July 14, 2003, 01:28:19 pm »
Thanx canstick.
I'll check out crappy tire!
Cheers,
Aricade
