Author Topic: Betson Imperial 19" (Kortek KTN-2001)  (Read 5487 times)
Boingo
  • Last login:March 14, 2014, 09:13:41 pm
« on: September 04, 2009, 03:44:43 pm »
I just got a 19" Betson monitor of of eBay from  a fellow called Crazy Hugo, and it came without a manual.
I am using it to replace a Wells and Gardner 19K7689 (in case it is relevant).
The monitor requires no isolation transformer.  So far so good.
The problem is with the video connection.  The existing monitor has a red green and blue connection (R,G,B)  to the JAMMA harness, plus a black for video ground and a white for sync.  The new monitor has red green and blue, a black, a white, plus a yellow wire.  The spot the connector plugs in on the chassis reads as H (white), V (yellow), E (black), and B G and R.
I want to hook the monitor up to the existing JAMMA harness.  Is this going to cause me any trouble?
« Last Edit: September 06, 2009, 10:02:16 pm by Boingo »
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: Betson Imperial 19" (Kortec KTN-2001)
« Reply #1 on: September 04, 2009, 08:19:56 pm »
You can just leave the yellow wire alone since your previous setup was using a  composite sync.
Boingo
« Reply #2 on: September 04, 2009, 10:05:11 pm »
Thanks.
Now to press gang somebody into helping me haul out the old monitor and lifting this one in.
 :afro:
Boingo
« Reply #3 on: September 06, 2009, 09:24:18 pm »
Help!
Help!
Help!  Something bad just happened!
 :embarassed:
I hooked up the monitor.  It ran for a while (but with no red, which I assumed was just a bad wire), but then it went off, making a funny high pitched squealing sound.
I have no idea what just happened.   ???
I can't believe this.  I only just put it in.
{{EDIT:  There was a spark when it first started up.  I thought it might have been a fuse at first, but the monitor worked ,albeit without red, but it may have been something more sinister.  Any help would be appreciated.}}
« Last Edit: September 06, 2009, 09:38:57 pm by Boingo »
Boingo
Re: Betson Imperial 19" (Kortek KTN-2001)
« Reply #4 on: October 23, 2009, 11:47:11 am »
I sent the electronic away to be repaired, and I just got them back the other day.  I went to put the electronics back in and  realized that I had forgotten to take a photo of where the plugs all go when I took it apart.  Now I do not know where to put the plugs back in.
If there is somebody who would be kind enough to post a photo of their Betson with the plugs all in their proper places, I would appreciate it very much.
