Author Topic: nintendo vs. monitor question  (Read 2333 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: September 04, 2009, 09:33:44 am »
I've got a nice NOS nintendo VS monitor but I've never worked on one.  Is it possible to hook it into a jamma harness or is there some odd wiring trick I need to do?
iscariot
Re: nintendo vs. monitor question
« Reply #1 on: September 04, 2009, 09:54:05 am »
Oh, let me update this... I know about the inverter board.  I was asking if I needed it or can I connect directly?
Kevin Mullins
    • Me on Myspace
« Reply #2 on: September 04, 2009, 11:17:39 am »
If the Sanyo has been converted specifically for particular Nintendo games, then yes you will need the Inverter Board.
It's easy to tell by looking for missing components replaced with jumpers on the chassis.
If you see the three transistor and resistors......then you don't need the inverter.
If you don't see them, then you either need the inverter or to replace those components to make it stock again.
iscariot
« Reply #3 on: September 04, 2009, 11:42:11 am »
So that's one in the picture that does not need the inverter to work with regular JAMMA games?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: September 04, 2009, 12:17:25 pm »
No...... that one in the picture DOES need the inverter...... missing components.
