Author Topic: New pictures of control panel...  (Read 1627 times)
gndprx
  • Last login:September 08, 2014, 11:25:49 am
  • nope...
« on: July 12, 2003, 09:36:19 pm »
Just posted some new pics of my control panel on my site.
http://www.caraudioresources.net/arcade
Almost ready to do the final touches.  Total left to do on the cabinet is get a permenant tv (the one in there now is from our bedroom), plexi bezel, final plexi CP, sound and marquee setup.
Let me know whatcha think.
EggZilla
  • Last login:January 17, 2004, 04:44:20 pm
Re:New pictures of control panel...
« Reply #1 on: July 13, 2003, 05:04:37 pm »
Looks nice, though I'd die without a dedicated 4-way. I noticed you're planning on edge-lighting it. I was just wondering how that would look the other day. I'll be interested in seeing how it turns out for you.
Cheers,
Eric
Like a bird on a wire,
  Like a drunk in a midnight choir,
   I have tried, in my way,
      To be free.
          - Leonard Cohen
isugoat
  • Last login:March 15, 2004, 10:46:51 pm
« Reply #2 on: July 13, 2003, 05:37:01 pm »
i like the dual layers on top to get the trackball flush...i don't have a mounting plate for my trackball so i'll have to steal that idea  ;D
what is that top part made out of, plexi?  would be nice to have clear plexi and then lay a design between the plexi and wood layer
gndprx
  • nope...
« Reply #3 on: July 14, 2003, 08:52:44 am »
Well, right now it's just 1/4" birch plywood over 1/2" MDF, however the 1/4" plywood will be used as the template to machine the 1/4" plexi to take it's place.
Would work fine to sandwich graphics under it as mentioned above, but I'm going to frost the entire panel (sand blast) so that when I edge light it, the entier thing glows.  Usually you can do this with LED's fairly easily, but I think I'm going to run a slot around the outside edges and sink EL Wire in there to try and get a very uniform lighting pattern.  I've done this often enough in my custom car audio installs, so I'm just transfering that knowledge to my cabinet in hopes of something a little unique ;D
May be a while before I get to acutally doing it though.  Still trying to finish off the rest of the cab first.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #4 on: July 14, 2003, 11:41:32 am »
dammit my post got lost!
Anyways...  gndprx keep up the good work.  I like your attention to detail/craftsmanship and slightly different approach to CP building.
I also like your MameWah skin with the controls/directions on screen...
Good job man! keep it up and keep taking pics of your progress!
Rampy
