Author Topic: Monitor issues  (Read 2142 times)
endrien
  • Last login:August 08, 2010, 08:33:36 pm
Monitor issues
« on: August 26, 2009, 09:32:51 pm »
So I just got a hatris cocktail and its got several monitor troubles, I've got a few monitor chassis from random tubes I can use for parts if need be. Firstly the monitor makes a hissing noise all the time(First time I plugged it in I thought it might blow up haha).
Secondly the screen is blurry and last is the screen is a tiny bit wavy(Probably a cap kit should fix it).
I'll get some pics up in a bit.
Thanks guys
Video:
« Last Edit: August 26, 2009, 09:38:27 pm by endrien »
endrien
Re: Monitor issues
« Reply #1 on: August 27, 2009, 02:07:54 pm »
Anyone? Hissing noise has stopped after some cleaning, Focus won't fix the blurry issue. There is no flyback arching.
grantspain
Re: Monitor issues
« Reply #2 on: August 27, 2009, 02:29:20 pm »
sounds like this was stored in a shed,the crt gets damp as thus your problems
best bet is to allow it dry out at room temperature for a few days and see what happens
also have you actually adjusted the focus on the flyback?
endrien
Re: Monitor issues
« Reply #3 on: August 27, 2009, 05:34:36 pm »
I have tried adjusting the focus on the flyback.
grantspain
Re: Monitor issues
« Reply #4 on: August 27, 2009, 05:37:16 pm »
check the focus wire from the flyback is soundly connected at the neck card
endrien
Re: Monitor issues
« Reply #5 on: August 27, 2009, 07:09:01 pm »
I tried reflowing solder to the focus connector, didn't do anything.
endrien
Re: Monitor issues
« Reply #6 on: August 28, 2009, 12:01:30 am »
I fixed the problem by adjusting a pot that was hidden by a Large capacitor.
SirPeale
  • Green Mountain Man
Re: Monitor issues
« Reply #7 on: August 28, 2009, 09:39:25 am »
Which pot?  Contrast?
