Author Topic: do i need more than one coin slot/button?  (Read 2208 times)
severdhed
  • RIP Dinosaur Hippo
« on: August 25, 2009, 11:50:50 pm »
i'm setting up a cabinet with a single 4 way stick, 1 action button and two start buttons, so i can play vertical classics on it.  i have an old 4 button gamepad here that i hacked a while back that i was hoping to use.  the D pad takes care of the joystick, but with 2 start and 1 action button, that only leaves one input available for coins.  is one coin input enough for these old classics?  i know certain games requre that you use coin slot 2 for player 2, but as far as i know, those are only for 2 (or more) player simultaneous games.  are there any good 4 way, vertical, 1 button or less games that will require that i have a second coin slot?
i have a 2 player x-arcade interface that i could use, but i have other plans for it if i dont have to use it.
any thoughts?
GaryMcT
  • Last login:September 24, 2014, 11:19:27 am
    • GaryMcT's arcade blog
Re: do i need more than one coin slot/button?
« Reply #1 on: August 26, 2009, 01:36:22 am »
Could use shifted buttons if you ever run into a game that needs the other coin button.  I'm working on a Mame mod for generic shift/modifier buttons. . hopefully I'll be done soon.
My blog on learning how to develop FPGA versions of arcade boards: http://garymct.blogspot.com
SavannahLion
« Reply #2 on: August 26, 2009, 02:10:58 am »
I did think MAME would support multiple keys for just this sort of thing, such as pressing A+B together would trigger Start 1. It does, but it also triggers whatever other keys A or B just happen to be bound to.
Then I remembered that GGG and Ultimarc products shift functions are hardware based, not software. So that got rid of that idea. I guess if you modify and recompile MAME, you would get the functionality you want. Otherwise.... :dunno
Beretta
« Reply #3 on: August 26, 2009, 02:26:33 am »
i think you're fine, if all you have is one joystick then you wont be playing any games that require more then 1 coin slot.. even games that supported more then one usually have a setting for a single "Totalizing" coin mech.
there maybe 1 or 2 games that are odd ball but i dont think you'll have a problem with going with just 1.
GaryMcT
« Reply #4 on: August 26, 2009, 02:57:45 am »
That's exactly what I'm doing.
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #5 on: August 26, 2009, 09:18:24 am »
Yeah, I think you should be ok with one coin slot too :) The only old games that used different slots were ones that took different coins (Defender had a 3rd slot in the middle that usually took Susan B. Anthony dollars, presumably giving 4 or 5 credits). I also remember seeing some older pinball machines with one slot that took dimes (for 1 credit) or quarters (for 3 credits) This of course, wouldn't be an issue with a MAME cab.
