Author Topic: Ultimarc U-Track Problems  (Read 4009 times)
seinfeldfan64
  • Last login:November 10, 2019, 09:41:38 pm
« on: August 25, 2009, 04:28:17 pm »
I've just purchased and installed a U-Track trackball... It doesn't seem to work right, spinning left and right the mouse cursor moves smoothly along the X axis. Spinning up the cursor moves rather slowly up, and spinning down the cursor hardly moves at all, kind of jumping up and down.  I would assume this is an issue with the track ball hardware itself?  I'm a rookie at this, what should I do?
fatfingers
  • Got UltraStiks?™
Re: Ultimarc U-Track Problems
« Reply #1 on: August 25, 2009, 06:22:34 pm »
I would contact Andy at Ultimarc.  He'll be able to get you going.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
severdhed
  • RIP Dinosaur Hippo
« Reply #2 on: August 25, 2009, 06:49:21 pm »
i had the exact same problem with my Utrak when i bought it.  i contacted Andy, he had me swap the PCBs inside, as it turns out, one was bad...he quickly shipped me out a new one and i was back up and working in a few days
seinfeldfan64
« Reply #3 on: August 25, 2009, 08:17:22 pm »
Thanks for the response guys.  I'll contact Andy.
ultrageek
  • Last login:August 23, 2012, 02:27:56 pm
  • If at first you don't succeed, you fail.
« Reply #4 on: August 26, 2009, 09:52:06 am »
I had the same problem with my HAPP 3" TB.  Turns out I had the power wires connected to the sensor connectors and vise versa. Almost exactly the same behavior.
One axis worked, the other was jumpy and extremely slow.
After switching them , everything works great.
I'm lucky I didn't fry the boards in the TB.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: August 26, 2009, 01:40:24 pm »
I have replied by email but one possibility is loose screws  on the optical spoked wheels from insufficient tightening on assembly. We have recently introduced a manufacturing change to use threadlock on these screws.
Easy fix to tighten the screws.
Andy
seinfeldfan64
« Reply #6 on: August 26, 2009, 05:28:04 pm »
No loose screws.  Turns out if I apply a little pressure on the PCB toward the wheel, it works much better.
