Author Topic: Bottom Mounting Happ Joystick..to route or not to route?  (Read 4701 times)
secretagentwd40
  • Last login:February 21, 2010, 03:56:50 am
« on: August 21, 2009, 12:06:15 am »
Hey everybody, I'm working on a small 1player Dreamcast stick and had a question about routering(is that a word??) the space for the stick.  I've finished my cabinet other than a few small details and bottom mounted the Happ Supers and also routed out enough space so that the top part of the base was flush with the bottom of the CP.
So Im using an IL competition stick for this small dreamcast panel, and was wondering should I even route out any space from the bottom, or will it be at a standard length just without routing it?  I am using 3/4" MDF by the way.
I've been looking and have found where Sanwa sticks are best mounted roughly 1/4" under the top of the panel, but haven't found any recommended numbers like this for any of the Happ sticks.
Thanks for any help guys
miles2912
Re: Bottom Mounting Happ Joystick..to route or not to route?
« Reply #1 on: August 21, 2009, 12:13:15 pm »
I routed just enough material out so the base would fit flush.  It is just a matter of personal preference.   Just see where the stick feels good and go from there.   Here is a pic showing what I did.
BTW - that is a pic of the TOP of my CP.  I bottom mounted my Happ Perfect 360's because the shaft length was fine.
« Last Edit: August 21, 2009, 12:33:07 pm by miles2912 »
secretagentwd40
« Reply #2 on: August 23, 2009, 01:40:51 am »
I ended up making a test panel with a piece of scrap wood, i started with a unrouted bottom mount, and tested many different depths til i settled on routing 3/8" from the bottom of the 3/4" MDF, which made the top of the base of the stick 3/8" from the top of the panel.
eaconner
  • Last login:February 27, 2013, 11:15:42 am
    • WV Arcade Club
« Reply #3 on: September 18, 2009, 11:02:07 am »
I bought 2 Ultimarc Mag-Stik Plus and did not route. I decided to make my CP out of 1/2" plywood, I counter sank the mounting bolts. I am very happy with the results.
« Last Edit: September 21, 2009, 11:21:52 am by thelarry8675309 »
BamBam
  • Last login:November 03, 2011, 07:18:19 am
  • This is better than Disney Land man!
« Reply #4 on: November 01, 2009, 09:49:36 am »
I have two teenage boys that are tough on everything, so I went with a flush mount on 3/4" MDF with extended shafts.
Galaga... Was there any other game?
