I used a nokia 3589i battery for a suitcase 286 compaq machine once and it lasted a super long time PLUS i can recharge it in a old unused cell phone!
the only problem w that was the perticular computer takes so mutch power if i leave it for a month it kills the c-mos battery GEE its only taking more than 1.5 amps since the battery is a 1500mAh battery then it must be taking a ˝ amp a day WoW thats a lot of power but once it get it to boot it seems to remember the harddrive boot bit and works I could care less about the clock!! it only boots to bowling gwbasic dos or adventure
yes you want instructions.
PS on a or any else thing or like a arcade pcb the nokia cell phone if charged battery would last more than 12 years since a 2032 would last 3 years a nokia battery witch would have more current should last 12 years or more but remember it only puts out 3.3v so add two in series then you get 6.6v and you could add to a 5v input and get 6.3v witch should be ok..
I hope you never have a boot problem w defender and be happy you have a button cell hole instead of a battery holder for aa batterys witch SUCK .
mu freind had a Nintendo Punch out pcb w crappy batterys removed but the connections were crusty I told him youre lucky you got to it when you did or the springs would have rusted off on the bat holder..
I also remembered you can get a super fat version of a 2032 but even bigger one is differnt number but way fatter and lasts even longer . Good luck .. ALso i heard there is a nvram mod for mr do witch sounds like any game could be changed if you knew what was done to mrdo and change out nvram and change program to allow guy who made that mod must program.. I can burn eeproms now 2532 and 2732 and 2716 tms2716 and can copy 9316 and burn 2764 27256 and 27c010 the only thing i cant program is a tms2716 w out copying it from a 2716! the tms needs -5v and 12v and 5v+ then move a10 poin 19 and 20 around and you can read.....
the good news is on my space invaders pcb I read a 9316 then ran it in mame and it booted to mame then took a deluxe tms2716 and changed it to a double socket mod and a test space invaders test rom i downloaded onto a 2732 then to a 2532 then to a 2716!!!!! two eprom burners one old and can change brands and types and copy from one type to nother the other burner is a $15 from ebay that can progam normal 2732 but not 2532 but the other one can change from one to other ... then i took 2716 non tms and made it work in normal space invaders tms2716 configuration w out touching strappings just used two sockets and rewired the two sockets to only deal w pins 18-21 then swaped 19 and 20 then connected 5v where it needed it then the whole pins 1-12 leave alone you only have to move pins 18 19 and 20 then you can use the two sockets to make the chip look like a tms2716 as long as you dont let 12v or -5 onto the 2716 it will read like a tms2716 !!! this means you can and i can run space invaders test rom on original board!!! it worked .. now onto learning about basic stamps and nvram so i can make a basic stamp just to emulte a ram chip on any arcade game so like defender you wouldnt need battery! the basic stamp would have socket output to the place where the battery back up chip goes and make it remember like the mrdo mod..
anyway I rambled to long today sorry...
