Author Topic: PPJoy to Key And Jaguar  (Read 1659 times)
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« on: August 08, 2009, 10:27:55 pm »
Hello,
 For a long time I have looked for a way to use my
HotRodSE with the Jaguar Emulator: Project Temptest.
The Emulator apparently only accepts joystick input. :(
 Then I found several posts talking about PPJoyKey...
several Hours later I found a partially working solution:
Here is what I did:
Emulator is in a folder called Jaguar
Z:\Jaguar
I copied all the contents from
C:\Program Files\Parallel Port Joystick
to:Z:\Jaguar
I created a folder inside
called "JoyConfig"
Z:\Jaguar\JoyConfig
my profile named emustick.ini
Z:\Jaguar\JoyConfig\emustick.ini
I have made a .bat file that will launch The Jaguar with
Alien VS Predator selected.
Here is the contents of :Alien vs Predator.bat
START PPJoyKey.exe JoyConfig\emustick.ini
START Z:\Jaguar\pt.exe AvP.jag
Now the only problem is I can't figure out how to auto kill
PPJoyKey on exit and have to do it manually.
If I can get that this will be perfect!
« Last Edit: August 08, 2009, 11:34:44 pm by TeutonicDarkness »
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
Re: PPJoy to Key And Jaguar
« Reply #1 on: August 09, 2009, 07:29:54 am »
l use a program that comes with XP Pro called pskill.exe. If you havent got it google it and downloaded it . below is a command that you can use as a bat file to close ppjoykey.
l use this with mamewah, for it has post_emulator_app_commandlines.
C:\pskill -t ppjoykey.exe
TeutonicDarkness
« Reply #2 on: August 09, 2009, 02:09:09 pm »
Yes tried pskill, even process, I cant even get it to even launch
with a shell ...let alone kill it!  ;)
( Tried more than 1 shell too! )
It seems to only work from within Windows though
I cant figure out why?
