Author Topic: WG monitor issue on P456 board - sparking?  (Read 1974 times)
Snazzy81
  • Last login:January 31, 2012, 11:22:30 pm
« on: August 07, 2009, 09:59:47 pm »
Hi,
I have a WG monitor with a 456 neck board.  I notice that it's out of focus and when I turn up the focus the entire picture shrinks down to a line - like a deflection problem.  I also notice that there seems to be sparking at the same time the deflection problem happens inside the socket part of the neck board that plugs into the tube (SKT201).  When I shut the lights off I notice the part of the socket where one of the wires from the focus control seems to light up from within.
This isn't a picture of my board, or even the same PCB.  Mine lights up where the black wire with the yellow connector attaches to the socket.
Any help would be appreciated. :)
« Last Edit: August 07, 2009, 10:01:30 pm by Snazzy81 »
Ken Layton
  • Guru
  • Technician
Re: WG monitor issue on P456 board - sparking?
« Reply #1 on: August 07, 2009, 11:26:48 pm »
Bad solder connection inside the socket. Possibly moisture in there too.
Snazzy81
« Reply #2 on: August 08, 2009, 12:18:32 am »
Interesting, so inside the socket itself or the connections to the PCB?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 08, 2009, 12:34:31 am »
Where the focus voltage wire connects inside the socket assembly.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: August 09, 2009, 10:18:28 pm »
in other words , replace the skt .
there is an internal spark gap  (over voltage protection) that can corrode , and repeated arcing can
build up a conductive carbon trace ..
fyi, typical focus voltage is 8kv-12kv
Snazzy81
« Reply #5 on: August 10, 2009, 10:28:26 pm »
Great, thanks for the info!  Where do I get a socket like this?
