Author Topic: RGB to Hi-Res VGA Converter  (Read 1541 times)
vertygo
  • Last login:September 20, 2015, 03:19:59 pm
« on: July 31, 2009, 04:42:44 pm »
Hi All,
I just got an email about this thing from JB (I know I know, we all hate them All-In-Ones)..
BUT, this did get me to thinking, and please excuse my ignorance of how light guns work..
1) Would you be able to plug a light gun setup that needs a regular tube tv onto this contraption ? Thus it would do the split-second screen blanking that they need to register the "shot" ? Mind you, I wonder if that would somehow kill your LCD after awhile ?
2) If NOT, then wouldn't something LIKE this be part of the solution to the whole light gun problem ? a board in between the pc and lcd that tricks both the guns and the tv into thinking they are back in retro-goodness ?
Just putting it out there :)
Ginsu Victim
  • Last login:June 08, 2026, 03:12:14 pm
  • Comanche, OK -- USA
Re: RGB to Hi-Res VGA Converter
« Reply #1 on: July 31, 2009, 05:01:32 pm »
I don't think you're even allowed to link to them here. You might wanna remove that link.
vertygo
« Reply #2 on: July 31, 2009, 05:29:08 pm »
I'll let a moderator decide, obviously I'm not doing it to be malicious by any means.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: August 01, 2009, 05:08:01 am »
The only way this would work is if you simulated a CRT scan on an LCD. So, when the trigger is pulled you would need to first blank the screen, then make each pixel white in the same way as a CRT beam scans across the screen, then detect which pixel makes the gun respond.
Theoretically this is possible but not the best way to design an LCD-compatible light gun.
protokatie
« Reply #4 on: August 03, 2009, 07:18:03 am »
Andy, is the state change of LCD fast enough yet for that to work? I know LCD's will work with Zapper style light guns because all that system does is turn the screen black, but with a white square where the target is, but I didn't think LCD's had a high enough response time for using a "light pen" style gun.  :dunno
