Author Topic: what is this spintrak part (screw?)  (Read 1935 times)
saleem
  • Last login:February 07, 2012, 08:03:39 am
« on: July 30, 2009, 09:29:05 am »
i got my spintrak today and i bought the flywheel which came attached.the spintop was not,obviously thats because the spintrak needs fitting to the cp.now the flywheel is attached to the spintrak using 2 screws,they are allen key and they are screwins but,not screws.
it looks like i need 2 of these for the spintop.
if you look at the pic you can see the little holes these things screw into.
http://www.ultimarc.com/SpinTrak.htm
what are they called please so i know what i need to get.
thecheat
  • Last login:October 16, 2009, 11:58:55 am
Re: what is this spintrak part (screw?)
« Reply #1 on: July 30, 2009, 09:59:26 am »
You mean a set screw?
McMaster Carr for sure but you ought to be able to get 'em at a local hardware store. Should be able to get it from your spinner supplier.
saleem
« Reply #2 on: July 30, 2009, 10:11:35 am »
yes,thanks.i did indeed do some googling and found out they are set screws.but,the size?
i also dug up an old post while googling and its on site,so i made post there also i have contacted ultimarc.
bkenobi
« Reply #3 on: July 31, 2009, 11:21:19 am »
Shouldn't Andy have included these with the spinner kit?  The flywheel isn't much good without a way to attach it.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: July 31, 2009, 11:29:50 am »
Absolutely these should have been included. I thought we had weeded out all the ones without screws but looks like we need to re-check.
If you can drop me an email I will send them.
