Author Topic: i've got 3 old monitors that need help  (Read 1643 times)
jackspicer
  • Last login:January 28, 2010, 07:47:54 pm
« on: July 25, 2009, 06:43:01 pm »
The first is a wells gardner model no. 19k7901 The picture is a bright neon green after it warms up.
Next is a philips model no. 0019263 The picture flickers.
And last is a wells gardner model no. 19k4903 The color red wont show up on screen. But this one has BAD burn in, so a replacement is in order sometime in the future.
I can take pictures if anyone thinks it would help, but will a cap kit solve my problems? where can i find them? and if i wanted to replace the 19k4903 what is a good replacement price-wise?
SirPeale
  • Green Mountain Man
Re: i've got 3 old monitors that need help
« Reply #1 on: July 25, 2009, 11:15:38 pm »
We always recommend new caps if they're original.
Might be a problem with the green gun(#1), transistor might have shorted making it on all the time.
Phillips (#2) does not make arcade monitors, but they do make tubes.
(#3) don't replace the whole monitor, just get a new tube!  4600s are awesome monitors with great pictures.  As for the missing red, it could be several things, from a blown drive transistor on the neck board to a loose connection to a broken solder joint.
jackspicer
« Reply #2 on: July 26, 2009, 07:12:32 pm »
This is the monitor that has the philips 0019263 sticker, anybody know what it is?
And i found out that the monitor that dosen't show red will, but you have to slap the side of the cab and it only works 10% of the time... ???
« Last Edit: July 26, 2009, 07:22:56 pm by jackspicer »
Kevin Mullins
    • Me on Myspace
« Reply #3 on: July 26, 2009, 07:38:03 pm »
Wells Gardner K7000
Check for bad solder joints where the video input plugs into the monitor.
May want to check the neckboard too while your're at it.
SirPeale
« Reply #4 on: July 26, 2009, 08:21:51 pm »
Agreed.  Problems that change with impact are broken solder joints most of the time.
