Author Topic: Electrohome roll  (Read 2227 times)
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
Electrohome roll
« on: July 22, 2009, 12:07:35 am »
I have a Mame cab with an ATI 2400 and soft-15khz. I can adjust the monitor just so but the screen always wants to roll. Controls/pots are very touchy. Tried 640x480 and lower resolutions. Does something on this Electrohome need repaired?
http://www.youtube.com/v/C3xzIDvG9pE
Kevin Mullins
    • Me on Myspace
Re: Electrohome roll
« Reply #1 on: July 22, 2009, 02:56:34 am »
I'm assuming you tried adjusting both the Vertical Hold AND the Vertical Linearity pots. (?)
How do you have your sync input connected?
ncflagg
« Reply #2 on: July 22, 2009, 10:17:56 am »
I think I just twisted the sync wires together.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 22, 2009, 10:52:03 am »
Is the sync connected properly?
http://homearcade.org/BBBB/sync.html
ncflagg
« Reply #4 on: July 23, 2009, 06:53:34 pm »
You may be right there. I will try splitting up the sync. (and makie sure I'm not missing a pot somewhere)
DarkSide
  • Last login:March 08, 2026, 08:34:16 am
« Reply #5 on: July 24, 2009, 03:05:37 am »
I'm not sure if this is usefull, but i had the same problems with a Kortek Chassis, when connected to the PC, the picture wouldn't stop rolling, and the controls was very touchy, the solution was connecting a 5kohm resistor between video ground and horizontal/vertical sync wires.
ncflagg
« Reply #6 on: July 27, 2009, 08:49:57 pm »
Splitting the H and V sync was the answer. Oddly, after getting the sync corrected the color was washed out. After a lot of elimination I finally discovered that TWO of the VGA connector pins had fallen out! Namely, the blue and green pins.
Now I remember why I quit working on this project several months ago....  :)
Thanks, all.
I'll try to remember the resistor trick for next time.
« Last Edit: July 27, 2009, 09:56:27 pm by ncflagg »
