Author Topic: Pole Position on Namcos Museum  (Read 1647 times)
scorp.ius
  • Last login:February 05, 2013, 11:00:06 am
« on: July 17, 2009, 05:52:34 pm »
Hi!
I have the Namco Museum 50th Anniversary (PS2) and think Pole Position and Pole Position II ARE NOT  playable with the pad.
Is it possible to use a steering wheel?
Or am I doing something wrong? It is SOOOOO sensitive  :'(
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Pole Position on Namcos Museum
« Reply #1 on: July 17, 2009, 10:21:10 pm »
Not the ideal forum for this mate; we all play our classics on PC's, using controls we build ourselves.
Alpha17X
  • Last login:September 19, 2023, 01:44:51 am
  • wheee!
« Reply #2 on: July 17, 2009, 11:24:01 pm »
Yeah it's all home-made arcades here.
To answer your question though;  When namco planted the rom for PP onto the PS2 disc. they most certainly did not make adjustments between between the turning speed for a wheel, and a thumb-stick. A wheel does, work for the game, and it does work much better, the turns are still immediate but you don't slam into the sides and have a chance to correct your steering.
It's unfortunate case of bad porting.
I miss Retroblast :(
scorp.ius
« Reply #3 on: July 18, 2009, 04:00:51 am »
I know this, and have built two own arcades too... but this is an control question. and here should be many people who know about that.
thanks for the answear ;) i will try a wheel then!
« Reply #4 on: July 18, 2009, 07:19:51 am »
i think he means maybe this belongs in the consoles section, since it deals with a console.
