Author Topic: .187 Female Quick Disconnects  (Read 3373 times)
SirPeale
  • Green Mountain Man
« on: July 09, 2003, 09:56:27 pm »
I posted this in the for sale, and should have posted it here, as I don't have these for sale - yet.
How much is everyone paying for these?  If I've done my math correctly, I can get these for $5/100, plus I figure around a buck to ship in the US.
Insulated, blue end covering the base.  Not totally shielded.
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
Re:.187 Female Quick Disconnects
« Reply #1 on: July 09, 2003, 11:16:51 pm »
Here in Mansfield, TX it's about $6 and change (+ tax) for 100 of the type you're describing. (at Home Depot).
So it sounds like you're on the right track.
I'm not a freak!...
Oh wait...
Yes I am...
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
« Reply #2 on: July 09, 2003, 11:21:08 pm »
At the local radio shack its about 3 bucks for 15 of 'em.
You Sir, are a good man.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #3 on: July 10, 2003, 12:12:51 am »
$9 per 100 on Happ, where I was gonna order them before cuz apparently no hardware store in my town carries them.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: July 10, 2003, 06:36:15 am »
$4.50 per 100, here:
http://www.allelectronics.com/cgi-bin/category.cgi?category=196450&type=store
SirPeale
« Reply #5 on: July 10, 2003, 08:35:05 am »
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: July 10, 2003, 08:57:37 am »
Ah, but you forgot to add in shipping: $6.00!
True, but they also have good deals on terminal strips and the like, which I was going to split the shipping cost across :-)
SirPeale
« Reply #7 on: July 10, 2003, 01:02:40 pm »
Well, I just ordered a bunch.  I'll be offering these soon.  I'll post them in the 'for sale' forum when it happens.
Chris
    • Chris's MAME Cabinet
« Reply #8 on: July 10, 2003, 01:49:36 pm »
The blue-ended ones are for 12-16 ga wire... too big for control panels.  You need the red-ended ones, which are for 18-22 ga wire.  I've found the red-ended .187 disconnects at Ace Hardware; Home Depot only has the .250's here...
Bob Roberts has the fully insulated ones at $5.00 for 50.  Mouser.com has the partially-insulated ones at $8.10 per hundred (159-2817).
--Chris
--Chris
SirPeale
« Reply #9 on: July 10, 2003, 02:39:47 pm »
What?  Bologna.  I've wired my CP with the blue ones just fine.  They come in especially handy when you're putting more than one wire per connection.
I suppose it also depends on what gauge wire you're using on your CP.  I've used CAT 5-E, and it worked really well.
Tiger-Heli
    • Tiger-Heli
« Reply #10 on: July 10, 2003, 04:04:55 pm »
--Chris
And, as I said, allelectronics has the red or blue ones (partially insulated) at $4.50 for 100 (plus $6.00 flat shipping).
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #11 on: July 11, 2003, 02:24:03 am »
Really?  CAT-5 is usually 22-24 gauge, IIRC.  Not that I'm disagreeing with you.
I used 20 gauge wire, and red ended ones for the NO wires (single wire connection), and blue ended ones for the GND wires (two wires per for the daisy chain).  I could not fit two wires in the red ended ones.  *shrug*  I liked it once it was done, because not only were the wires color coded, but so were the disconnects.
Robin
Knowledge is Power
SirPeale
« Reply #12 on: July 11, 2003, 08:40:30 am »
Yeah, I went with color coding as well, but with the wires that I used, as opposed to the connectors.  Since the grounds are all connected to the same spot, I didn't see the need.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #13 on: July 11, 2003, 07:53:05 pm »
Uh, both the wire and connects were color coded for me.  Blue connects & black wire for ground, and red connects and red or green wire for inputs.  Color coding both is not needed, but it helps me. *shrug*
Robin
Knowledge is Power
SirPeale
« Reply #14 on: July 11, 2003, 10:54:09 pm »
Helped me too. I color coded the grounds as well, but didn't use black.  I used orange.
