Author Topic: Source for high quality potentiometers?  (Read 3337 times)
Mark Shaker
« on: February 27, 2002, 04:19:01 am »
Greetings,
I'm looking for some very high quality 100K Ohm pots to convert analog arcade controls for use with a PC.
I've only been able to locate ones rated from 5000 to 25000 cycles. That would not last very long.
Does anyone know where I can find some rated for 1 million+ cycles?
Thanks for your help!
  - Mark
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re: Source for high quality potentiometers?
« Reply #1 on: February 27, 2002, 07:52:45 am »
Consider hacking a Microsoft Dual Strike (new on ebay for 9 bucks).  The advantage is that it uses a 20k pot, but only turns about 1/4 of the way (ie, 5kpot).
note:  I haven't used one because when I could get my hands on a 5k pot controller, I didn't know how I wanted to hack it.
Anyway, people have had great luck with it and some say they don't even have to align the joysticks!
I've heard that they allow hotswapping the pots also.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #2 on: March 01, 2002, 12:32:08 am »
The dual strike method works great, but what are 5k pots rated for?
My other job...
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« Reply #3 on: March 01, 2002, 05:44:33 am »
Why don't you take a look at:
http://www.jameco.com
They have a huge selection of electronic parts and, if I'm not mistaken, they don't have a minimum order.
Good Luck!
"The Manuel"
Lilwolf_1
« Reply #4 on: March 01, 2002, 06:03:26 am »
btw, 5k pots are whats on most arcade analog joysticks.  So if you have an analog joystick it should be there.
The 5k pots at happs aren't to high.  The 100k are 5 times that amount.  These should have a super high rating.
JMDickson
  • Last login:October 21, 2011, 11:22:48 pm
« Reply #5 on: March 01, 2002, 06:32:33 am »
The higher the resistance on the IBM joystick port, the longer/more CPU cycles it takes to read the result.  The best performance wise is to use the minimum Ohmage that gives you the accuracy you want.
