Author Topic: coin lights  (Read 5258 times)
mr_doles
  • Last login:May 14, 2026, 10:04:05 am
  • nuff said
coin lights
« on: July 15, 2009, 10:27:54 pm »
Got a question about adding lights to my coin door.  I have a Coin Controls double frame mini door in a Dynamo Cab.  I have the wires and the wedge lampholder just not sure about the lights itself.  Looking at other threads and google searches I see people talking about 5V lights and 12V lights, the coin control manual shows the part as a 6V wedge base lamp.  What voltage do I need to get and is this something I can pick up in the automotive section of Wallmart or Lowes or is this a special order.  I know Coins Controls has changed hands and no longer makes these.
Ken Layton
  • Guru
  • Technician
Re: coin lights
« Reply #1 on: July 15, 2009, 11:30:32 pm »
Generally, Dynamo used 6 volt lamps powered from the +5 volts of the power supply. However, there are some Dynamo cabinets out there that are wired to feed +12 volts to the coin door lamps.
If you have 5 to 6 volts going to the wedge base coin door lamps, then these bulb numbers are acceptable: 555, 159, 259.
If you have 12 volts going to the wedge base coin door lamps, then these bulb numbers are acceptable: 161, 194, 658.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: coin lights
« Reply #2 on: July 16, 2009, 06:29:50 pm »
Bob Roberts recommends using the 12 volt line, since most boards are too sensitive to the +5v and if a bulb burns out, it can cause a dip, spike or increase in the voltage
NO MORE!!
Ken Layton
  • Guru
  • Technician
Re: coin lights
« Reply #3 on: July 16, 2009, 10:49:08 pm »
Now here is where I disagree with Bob Roberts. I use the +5 volts to power coin door lamps. For one thing, the +5 volts is "protected". If there's a short circuit, the +5volts output simply shuts down usually without damaging the power supply. The vast majority of power supplies have plenty of "headroom" (amperage) available that a couple of coin door lights are not going to overload anything. The +5 volts is also "soft start".
The +12 volts and -5 volts are not protected. If there is a short circuit (even momentary) like say from a +12 volt lamp filament burning out, you'll blow the power supply.
RayB
  • There's my post
    • RayB.com
Re: coin lights
« Reply #4 on: July 17, 2009, 10:38:09 am »
Good to know, and I trust your opinion 100%!
NO MORE!!
LLUncoolJ
  • Last login:April 23, 2015, 03:08:00 pm
  • This snowflake tastes like fish sticks!
Re: coin lights
« Reply #5 on: August 06, 2009, 09:07:11 am »
You wouldn't happen to know what bulbs are used in the coin door for  a Williams system 11 pinball (1989 Earth Shaker), wouldja?
You probably remember me from such films as `The Revenge of Abe Lincoln' and `The Wackiest Covered Wagon in the West'
Gameroom pics at http://forum.arcadecontrols.com/index.php?topic=89006.40
SirPeale
  • Green Mountain Man
Re: coin lights
« Reply #6 on: August 06, 2009, 09:36:37 am »
Probably 555.  Either that or 44/47.  I can't remember if they're wedge or bayonet based.
LLUncoolJ
Re: coin lights
« Reply #7 on: August 06, 2009, 10:02:26 am »
Cool, I know I have some 47's, and I think I may have some 555's. I haven't had time to toy with it much lately. I am expecting the arrival of my new baby (Theatre of Magic) this weekend. Maybe that beauty will prod me into cleaning up ES.
SirPeale
Re: coin lights
« Reply #8 on: August 06, 2009, 10:35:23 am »
A good rule of thumb with pin lighting is that 555 and 44/47 are the most common bulbs used.  You can't go wrong with having them on hand.
