Author Topic: dressing up in heavy gear makes you hot?!  (Read 2185 times)
« on: July 14, 2009, 03:00:21 pm »
A federal judge in Ohio concluded that manufacturer Riddell Inc. had a duty to warn Stringer that its helmets and shoulder pads could contribute to heat stroke when used in hot conditions.
People need to be told that being 325lb, dressing up in heavy equipment, and running to exhaustion in 100 degree heat can cause heat stroke...?   :banghead:
Ginsu Victim
  • Last login:May 05, 2026, 05:31:58 pm
  • Comanche, OK -- USA
Re: dressing up in heavy gear makes you hot?!
« Reply #1 on: July 14, 2009, 03:05:49 pm »
Thomas Payne wrote something Stringer should've read...
Check out my first product, The Tone Ledger, a premium workflow tool designed for guitarists, bassists, keyboardists...pretty much anyone who enjoys using amps and pedals.
« Reply #2 on: July 14, 2009, 03:10:20 pm »
Maybe my brother and I should sue them for not telling us we might get frostbitten if we wear them in subzero temperatures for hours.
Ginsu Victim
« Reply #3 on: July 14, 2009, 03:20:22 pm »
Ah, the other extreme. I think you might have something.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: July 14, 2009, 06:51:31 pm »
Yup..... that federal judge needs a kick in the balls.
Typical, let's lay the blame on a manufacturer......never the coaches, school staff, parents, etc.
That's like saying every coat mnaufacturer, motorcylce leathers manufacturer, welding gear manufacturer, etc should all give the same "warning" to their consumers.
What a bunch of dumbasses..... COMMON SENSE.
I perosnally have two boy that played football and I was CONSTANTLY asking about water breaks, pads/ no pads, etc. And let me tell ya, it gets hot here with high humidity.
COMMON SENSE
danny_galaga
  • Last login:May 07, 2026, 01:35:21 pm
    • dans cocktail lounge
« Reply #5 on: July 15, 2009, 07:02:43 am »
I think dressing up in heavy gear is over rated. Doesn't make you look hot at all  :dunno
SithMaster
« Reply #6 on: July 15, 2009, 08:47:48 pm »
I think this is the heavy gear being referred to.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #7 on: July 16, 2009, 07:05:18 pm »
True...true.  But it does make you look like you went a little overboard on the 'roids.
You should try out for the MLB while wearing that.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
