Author Topic: Visual Pinball Key Issues...any idea?  (Read 4941 times)
sk8ersublime
  • Last login:March 24, 2026, 04:50:43 pm
« on: July 03, 2009, 06:16:47 pm »
Hello everyone,
So I have been rapidly adding programs to my cabinet, I put on Future Pinball the other day, and its great.  But a lot of my favorite tables are on Visual Pinball.  So i installed Visual Pinball on my cab and got it running, but I am having an issue, I have set my Keys to the following in Visual Pin:
Left Paddle = 3
Right Paddle = 4
Coin = 5
Start = 1
tilts are = C, left Crtl, and ]
I have also set this up in PinMame by using the Tab menu.
But when I press the paddles, they add coins, it wouldnt be that bad, except that most tables make sounds when you add coins and it gets really annoying.
I have read that Visual Pinball by default uses 1-5 for paddles, coins and stuff.
So my question, how the hell do i change the default values??
Ive tried search but I can find what exactly to do.....and if it helps, im using an X-arcade DIY kit for my panel....
Thanks in advance,
Chad
mlalena
  • Last login:June 12, 2021, 12:31:44 pm
Re: Visual Pinball Key Issues...any idea?
« Reply #1 on: July 03, 2009, 08:38:31 pm »
I thought both Future Pinball and Visual Pinball used the same controls.
Many of these controls are the same keys as in MAME so I wired 2 buttons to the same pin on my IPAC.
Coin = 5 = Same as MAME
Start = 1 = Same as MAME
Left Paddle = Left Shift = P1 button 4 in MAME
Left Tilt = Z = P1 button 5 in MAME
Right Paddle = Right Shift = P3 button 2 in MAME
Right Tilt = /
Center Tilt = Space = P1 button 3 in MAME
Plunger = Enter = P3 button 3 in MAME
Are you implying that it works in Future Pinball, but you had to resort to this odd mapping for Visual Pinball?
sk8ersublime
« Reply #2 on: July 03, 2009, 11:51:15 pm »
Future Pinball works fine. All keys only press what they are suppose to.
but in Visual Pinball w/ PinMame, when i press '3' or '4' which is what the X-arcade default side buttons are, it is the right/left flipper, and it adds coins.
I have changed the Keys in both Visual Pinball, and PinMame, so I am guessing that they are hardcoded in some file and its not changing when I make the changes.
