Author Topic: Best Emulators to use for......  (Read 2352 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« on: June 30, 2009, 02:56:10 pm »
I have a 27" WG D9200 Arcade Monitor and I'll be using MaLa as my front end.
I wanted to know what the best emulators to use are for the following(what version if it applies):
- Genesis
- NES
- SNES
- Dreamcast
- PSX
Also what Resolutions should I use for each emulator.
SparkyGoBlue
  • Last login:August 01, 2022, 04:06:45 am
Re: Best Emulators to use for......
« Reply #1 on: June 30, 2009, 04:02:06 pm »
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #2 on: June 30, 2009, 06:35:15 pm »
I collected emulators wihich is great using for emulators to been used on a cabinet:
http://www.multife.com/index.php?page=help&faq=emulator.setup
Even the link is was designed with multife in mind, it can of course too been used with other frontends since it very general. Howover not looked on PS1 emulator, which I need look on....
thomascirca
  • Last login:December 07, 2011, 08:36:44 pm
« Reply #3 on: July 01, 2009, 03:30:37 pm »
- Genesis
- NES
- SNES
- Dreamcast
- PSX
Depends a bit on what kind of system you're running. Here's what I recommend:
NES: FCEUX or JNes (FCEUX seems to work better with frontends)
SNES: ZSNES
Dreamcast: NullDC (Dreamcast emulation might be a bit buggy depending on what you got going)
PSX: ePSXe
Those are just my personal perferences. Monitor resolution of course depends on your monitor. 640 x 480 should be fine for all, might want to bump it up for Dreamcast emulation in order to fully enjoy the greatness that is Dreamcast.
« Reply #4 on: July 01, 2009, 04:18:01 pm »
On a related note, is there any other emulator for 3d0 other than Freedo. It seems quite buggy and the latest version appears to only have russian text in it    :(
