Author Topic: nt-2701 chirping  (Read 3661 times)
ZMB
  • Last login:May 14, 2010, 07:46:29 pm
nt-2701 chirping
« on: June 18, 2009, 03:59:00 pm »
I have two chasis boards that have come out of goldentees. both are nt-2701s and make a chirping sound and thats about it. One of them blew the 10uf np c550? any help will be awesome.
Kevin Mullins
    • Me on Myspace
Re: nt-2701 chirping
« Reply #1 on: June 18, 2009, 05:22:20 pm »
Not NT2701 specific..... but I would start with checking the voltage regulation. (B+)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: June 18, 2009, 05:30:19 pm »
any time a smps is chirping , always check for shorts or heavy loads on the secondary.
have a look at the h out xistor . likely shorted.
 that cap is in pin correction, so check the pin out xistor as well.
i will need to pull a print to provide specifics...
qrz
ZMB
« Reply #3 on: June 18, 2009, 05:43:05 pm »
The B+ is pulsing with the sound of the chirp. My meter is not fast enough to give a decent reading but from what my fluke gave I was seeing anything fro 0.007 to 2 vdc. I wil pull the H xsistor and see if things settle down.
ZMB
« Reply #4 on: June 18, 2009, 06:14:25 pm »
ok...just got one of them up....the H out tranny was shorted Q402...one more board to go.
ZMB
« Reply #5 on: June 18, 2009, 06:32:58 pm »
on the other 2701 I pulled the h xsistor out and powered it up and I now have a B+ at 105 vdc....flyback perhaps?
ZMB
« Reply #6 on: June 18, 2009, 07:09:24 pm »
ok...I replaced the H out (bu2532al) with a 2sc5589...I now get a solid vertical line...no horz deflection....any clues as to where to look next?
qrz
« Reply #7 on: June 18, 2009, 09:41:27 pm »
just to verify your terminology :
loss of vertical deflection results in a HORIZONTAL ( r/l) line across the center of screen.                 -------------
        i
loss of horizontal deflection results in a VERTCAL (top/bottom) line in the center of screen.                      i
        i
if it is the 1st item, check the vert output circuitry.
2nd item, look for a cold solder joint/burn mark on foil side of pcb near yoke connector
qrz
