Author Topic: Ms. Pacman JS and Wood  (Read 2817 times)
sam
« on: March 01, 2002, 09:41:27 am »
anybody have results on mounting this joystick (Ms. Pacman/Galaga) on a wood panel. the happs site says it is for a metal panel, and the shaft length does look pretty short. still, i was wondering if anyone has tried this.
my control panel uses 1/2 inch plywood, was hoping there was some way i could use this stick with it.
sam
J_K_M_A_N
Re: Ms. Pacman JS and Wood
« Reply #1 on: March 01, 2002, 09:44:26 am »
I have that joystick and i had a friend make a metal panel for me. You can see it on my site. The joystick does rock though. I love it for all 4 way games. It has a great feel and good spring. If you can get a metal panel made, I highly recommend it.
J_K_M_A_N
Joe's Arcade Machine
http://jkman999.tripod.com
sam
« Reply #2 on: March 01, 2002, 01:16:10 pm »
are people's impressions that it won't work on wood. even just 1/2 inch plywood?
Scott Albright
« Reply #3 on: March 01, 2002, 02:39:01 pm »
I used 5/8" MDF for my cabinet & CP and then routed out an area large enough for the Ms. Pacman joystick from Happ Controls.  I probably routed it down to 1/4" and it worked fine.  I just routed from the bottom.
slug
« Reply #4 on: March 01, 2002, 06:21:39 pm »
I am using a 3/4 mdf C-panel.
I routed out the area of the joystick to about 3/16 or 1/4
inch, I made 2 wooden spacers with drilled holes for
each side of J-stick. the spacers fit betwwen the joystick
and a small piece of plywood which extends past the routed area and allows me to use long screws into the 3/4" part of the C-panel . I  put bolts thru J-stick spacer and plywood and I use 3 scews on each plywood "wing" into the control panel.
This worked out so well for me I mounted all my Joysticks this way because it gives you a lot of height
on your sticks and they are extremely solid.
                           good luck
                              Slug54
