Author Topic: anyone ever wire the $25 wico Trackball to an Oscar USB interface?  (Read 2908 times)
Hoagie_one
  • Um....whats a cabinet
Just wondering if anyone had any experinece in this.  I'm trying to keep my costs down if I can and if I could wire it this way, it would be the cheapest method.
TRACKBALL
INTERFACE
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
Re:anyone ever wire the $25 wico Trackball to an Oscar USB interface?
« Reply #1 on: July 07, 2003, 10:24:09 am »
I have a Wico 2.25" trackball and the Oscar USB interface.
Works like a charm.  I am pretty sure the connectors are the same.
ny
Hoagie_one
« Reply #2 on: July 07, 2003, 10:27:38 am »
EXCELLENT.
THANKS
Mike
  • Last login:September 22, 2005, 01:22:14 pm
  • Umm, yea about the TPS report
« Reply #3 on: July 07, 2003, 11:36:01 am »
I have my wico trackball and oscar spinner both wired into my oscar interface.
Hoagie_one
« Reply #4 on: July 07, 2003, 11:37:48 am »
Both are wired into one oscar interface?
Cool.  Then I only have to buy one
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: July 07, 2003, 02:03:09 pm »
I hope Mike meant Optipac :)  Anyway, you cna hook two trackballs to an optipac.  So you should have no problems.
Hoagie_one
« Reply #6 on: July 07, 2003, 02:17:13 pm »
I'm trying to avoid buying an optipac actually, so I hope he meant oscar's interface
SirPoonga
  • Puck'em Up
« Reply #7 on: July 07, 2003, 02:29:19 pm »
Oh, in that case oscar's interface is just a mouse hack.  If Mike has both hooked to it then you can't use them at the same time.  The trackball just make a decent second playter spinner if that is ever needed (hmmm, warlords).
Hoagie_one
« Reply #8 on: July 07, 2003, 02:35:13 pm »
Thats fine.  Dont expect too play many two player spinner\trackball games.  thats mainly for one player stuff.  I got the two stick and buttons for most 2 player games
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #9 on: July 07, 2003, 02:39:02 pm »
sort of off topic, but not that much. at ultimarc's site, they say that the trackball they offer is fitted to work with te optipac. can this work with oscars usb mouse interface, or must i buy a tb from wicothesource? and if i want the interface with 2 buttons, i only need 1 (interface) , right? asking b/c it says spineer interface and a trackball has double the axis of a spinner.
« Last Edit: July 07, 2003, 02:46:53 pm by jakejake28 »
It's all about the Pentiums
SirPoonga
  • Puck'em Up
« Reply #10 on: July 07, 2003, 10:48:17 pm »
you should be able to get almost any tball working with either interface.
OSCAR
    • Oscar Controls
« Reply #11 on: July 07, 2003, 10:52:58 pm »
...and if i want the interface with 2 buttons, i only need 1 (interface) , right? asking b/c it says spineer interface and a trackball has double the axis of a spinner.
Only one interface is required for a trackball.  Both the x- and y-axes are able to be used on the USB mouse interface since a pin header for each axis is present.
