Author Topic: pictures waves & breathes  (Read 1414 times)
pinballwizard79
« on: June 11, 2009, 10:26:17 pm »
I have a picture that moves just a little bit, like its breating or warping in & out just a little bit.
It sucks.
Any ideas on the cause?
I thought interference but that doesn't seem to be the case.
LCD's of 32' are like $325 now @ Costco, it may finally be time.
Kevin Mullins
    • Me on Myspace
Re: pictures waves & breathes
« Reply #1 on: June 12, 2009, 01:40:20 am »
Sounds like it may be a B+ voltage issue. (?)
Like it's a tad low or something.
Could be a bad cap.
Main filter cap possibly.
Is everything grounded real well?
Is this on your 33" WG ?
« Last Edit: June 12, 2009, 01:43:48 am by Kevin Mullins »
pinballwizard79
« Reply #2 on: June 12, 2009, 10:36:47 pm »
Meh never mind, I am just gonna throw this away & go LCD flat panel with a 5 year service plan.
Ive already had to have a new pot installed, prior to that the board was shipped out for some cap work, the power supply fan seems to run a lot, the resolution sucks, its dangerous to calibrate & dealing with graphic cards or a UVC is getting tiring.
CRT = headaches.
LCD = a half decade minimum of hi res for a mere $350
