Author Topic: Flat Bezel?  (Read 2417 times)
Roughy
  • Last login:July 01, 2009, 09:33:20 pm
  • Easily impressed.
    • UserGlue
Flat Bezel?
« on: June 11, 2009, 11:54:42 am »
I've recently upgraded myself to a nice 27" monitor in my cab, but I'm left with some limited space for a bezel.  Granted, I inherited the bezel that I'm currently attempting to use, but it seems a bit "tall" from the monitor to the rest the bezel.
I could order the standard 27" bezel from Happ, but I'm wondering if there's anything that's either flat or something that could go on the outside of my plexi that looks pretty good.
Any thoughts or suggestions?
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Flat Bezel?
« Reply #1 on: June 11, 2009, 02:05:56 pm »
We have used black roofing paper fastened to the inside of the plexi. Of course you have to cut a hole to compliment the picture on the picture tube.
Hope this helps.
Good luck
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Kevin Mullins
    • Me on Myspace
Re: Flat Bezel?
« Reply #2 on: June 11, 2009, 02:25:44 pm »
I know the bezel in a San Fransisco Rush with a 27" is nothing more than a black flat piece of cardboard with the screen area cut out and then is stapled to the inside of the cab behind the glass.
Don't over think it.  ;)
Ginsu Victim
  • Comanche, OK -- USA
Re: Flat Bezel?
« Reply #3 on: June 11, 2009, 02:27:41 pm »
I'm just using foam core from walmart.
Kevin Mullins
    • Me on Myspace
Re: Flat Bezel?
« Reply #4 on: June 11, 2009, 04:33:42 pm »
Yeah, that stuff works good for lots of things.
I've used it for cutting stencils and such as well.
Like this:
http://www.artsupply.com/brand/foamcore.htm
You can get it in all kinds of colors down at some of the bigger hobby stores like Hobby Lobby or whatever is in your area.
BASS!
  • Just have fun.
Re: Flat Bezel?
« Reply #5 on: June 12, 2009, 04:02:40 pm »
I always see people recommend foam core, and working in a sign shop using the stuff I would have to caution against it. The main reason I would stay away is fading. A sheet will only take a couple months before it starts looking washed out. One method I have yet to post on that I love is light diffuser sheets from a hardware store. They are the sheets you get to put over your florescent lights, and they come in all shapes and sizes.  You can get a sheet for 5 bucks, and just take a sharp razor and cut the shape out. For the bevels, just cut some strips and hot glue them in. Once you get the shape, spray paint black and you are done.
Ginsu Victim
Re: Flat Bezel?
« Reply #6 on: June 12, 2009, 04:09:00 pm »
My foam core is behind tinted glass, so it looks black at all times. The foam core is kinda gray to begin with, so the tint helps.
Kevin Mullins
    • Me on Myspace
Re: Flat Bezel?
« Reply #7 on: June 12, 2009, 04:28:12 pm »
Yeah, if you're talking about doing "signs" that are generally outdoors in the sun.
I've seen good vinyls do the same thing.
If you are going to recommend painting..... why not just paint the foam board as well?
I'm not knocking ya, everyone has they're own experiences with different things.
Some good, some bad.  :cheers:
BASS!
  • Just have fun.
Re: Flat Bezel?
« Reply #8 on: June 12, 2009, 05:36:11 pm »
Not knocking, just my experience :). To each their own, I just am more surprised that, foam core is the statuesque. Foam core fades in any light other than complete blackness.  As far as painting foam core I guess you could, but why would you paint paper, It would most likely just sink in or cover really weird. I just hate foam core, yes I said it, I am a foam core hater. It smashes under any pressure, edges tear when you cut it wrong, and does not like any moisture/humidity. I have cut and used about 200 football fields of the stuff, and with all the things you could do with it, I would not say a permanent/semi-permanent bezel is the best. Hell it will get the job done though.
To follow up though, that plastic light diffuser sheeting is awesome, cheap, and paints very well. Just offering up a alternative that I found very useful.
Kevin Mullins
    • Me on Myspace
Re: Flat Bezel?
« Reply #9 on: June 12, 2009, 07:48:33 pm »
See all the foam core stuff I have used for different projects (not a bezel mind ya) has had a glossy colored surface. Still would only recommend indoor use for it. So maybe we're just using two different grades of the stuff or something. I personally actually use it mostly for cutting stencils. (for an authentic painted result) I've never had a problem cutting it, even with some details involved.
I'll have to check out that light diffuser sheeting you mentioned.
Always looking for alternative materials do different things with.  :cheers:
Ummon
  • Trade Count: (+13)
Re: Flat Bezel?
« Reply #10 on: June 12, 2009, 07:59:09 pm »
Could easily use matte or flat black card stock from arts/craft stores.
Yo. Chocolate.
Stephen Hawking
Kevin Mullins
    • Me on Myspace
Re: Flat Bezel?
« Reply #11 on: June 12, 2009, 09:22:17 pm »
Yeah, that's a good choice too. Similar to what I was trying to describe in the SF Rush's.
It's a bit thicker than your standard card stock and now can't think of what to call it.
Maybe they just called it "matte board" or something of the likes. Kinda like what you would use in picture frames.
