Author Topic: 8liners chassis question.  (Read 2360 times)
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
« on: June 06, 2009, 07:37:29 am »
I just recieved the chassis I ordered from 8liners website. It's a wei-ya 1220h.
I'm preparing to connect it to the tube I have, but the chassis didn't include any documentation.
There are 2 sets of connector pins on the board to plug the yoke wires into.
Which set of pins should I plug the connector into?
There is also a single pin next to the connector where the red wire is plugged into the board.
Do I connect the tubes ground strap to that pin?
Also, do I have to make any adjustments to the B+ pot, or is it properly adjusted from the factory?
Trample the weak, hurdle the dead
Re: 8liners chassis question.
« Reply #1 on: June 06, 2009, 08:31:25 am »
I dont know about the ground strap question, but I had a monitor that had 2 sets of inputs like that. One way made the picture normal, the other way flipped the picture upside down.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 06, 2009, 12:07:43 pm »
The red jumper wire is to select one of the two pins that set the width range: (N) narrower or (W) wider. You'll see the N and W markings on the board next to each post. Set the jumper wire to one or the other that gives the best width adjustment range on your picture. DO NOT connect a ground wire to these pins as you'll destroy the chassis immediately upon power up.
There are two sets of yoke connector pins on the chassis. One set gives a normal picture and the other gives a mirror image to use the monitor in cabinets that bounce the picture off of a mirror like Terminator 2. Only unplug/plug this connector when the power is off or damage will occur.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: June 06, 2009, 12:12:47 pm »
Typically the ground strap goes up to the neckboard.
I say typically because I'm not familiar with that particular chassis.
Leave it alone.
M.Lanza
« Reply #4 on: June 06, 2009, 01:16:45 pm »
Thanks. I think I got it now.
I didn't see the pin on the neck board.
 :D
« Last Edit: June 06, 2009, 01:18:24 pm by gimp_hand »
